VU+ streaming udp/multicast
jurim
Hi all!
Before I buy Vu+ receiver, I need to know if it would fit my needs.
I have read a lot of posts, but still haven't found answer for my question.
I know I can receive udp/multicast streams with Vu+. I also know Vu+ can stream http and I can watch these streams on PC (or any device which supports http stream). But is there any plugin that could stream udp/multicast? If there is, could you provide more details (what for should I search)? I know I can receive http stream and convert it to udp using VLC, but is there any way to do it direct from receiver?
P.S. By mistake posted this question in Spanish forum and got answer that this is doable, but need more details - how.
Just take vuplus player for pc android or phone and you do straming even outside if you have open the streaming port.
