RedZamboni
Weird, i'm told that the Vu+ Turbo C/T2 hybrid tuner is suppose to be supported by Black Hole, but it seems like that the SE model that every one are selling now obviously lacks support, because it can't be found in Black Hole 3.0.8 on my Uno 4K equipped with a DVB-S2 FBC tuner.
I have tried hooking the Turbo SE up on the back and on the side of the box and even tried completely shutting the Vu+ Uno 4K down using the power switch on the backside of the box, but still no luck.
In the Kernel Modules Manager, everything is even also set to Yes.
The Vu+ Turbo SE USB tuner just can't be found, even though its mentioned by Vu+ them selves that its suppose to be fully supported by all their Vu+ boxes.
So for me when Vu+ them selves tells its supported by all their boxes, then its obviously Black Hole 3.0.8 who lacks the support for the Vu+ Turbo SE C/T2 hybrid USB tuner.
Is it the case that the support for the SE tuner has been added to Black Hole 3.0.9, or is this something that yet has to come, now that i have made aware of the newer SE tuner issue?
