VU TURBO TUNER
mialy
Hi got vu+solo2 want to use vu turbo tuner I have done a full backup on a usb stick now want to flash new image bh 2.1.7 do I connect tuner up to box first or do I flash image first then connect tuner after or does anybody know of a guide on how to set up turbo tuner appreciate any help thanks mialy
You just need to flash your box with the 2.1.7 image, then plug the turbo tuner in, and reboot the box (you can plug the tuner in first if you wish, it won't make any difference).
Once the box boots, you should be able to setup the turbo tuner in the tuner configuration menu.
Thanks mialy
