hi
just bought umtimo , had vuduo, and its worst remote i have seen buttons r so small and very very hard u have to point out towards reciver otherwise it dont work, and like if ur uisng in dark u dont know which button ur pressing u have to turn on light,
all buttons r same small, 2 buttons press at 1 time with my finger, buttons should be diffrent like other recivers have , with out check u can press buttons all buttons should be soft remote range should be good i was happy when i was buying it but i am thinking if i can use duo remote with it duo remote is 1 % better then this
