Vu+ Ultimo 4k - Picons Display on Multi Epg
Blaze
I have free view picons on a usb stick how do I add the picons to the multil epg what men u do I use
thanks blaze
I have free view picons on a usb stick how do I add the picons to the multil epg what men u do I use thanks blaze
I presume from your history that you owns an Ultimo4k, right?
My question is, wich image are you using on it?
Note: After your answer, i will move your post to the correct section!
You have not answered completely to my post --> https://www.vuplus-community.net/bo...icons-display-on-multi-epg.40049/#post-264895
I presume, as i said early, you own a Vuplus ULTIMO 4K, right.
Next time, to not go OFF TOPIC, search on through the board, and try posting on the correct section, regarding the MODEL and image you have running on your STB.
BlackHole images are based on Vuplus OE 3.0, severall different code from OE-A based images.
Though, due to code and to not miss the merging code of Vuplus is not possible to make it display on Multi Epg screens ... only at Channel List.
If you need it, you can use Open BlackHole, and with it, you can do it!
