VU Ultimo 4K PIP Info
WWORPS
HI , i am a new user of this receiver and need help using the pip feature.
I have 2 tuners set up and want to watch news while viewing other channels. I don't SEE info about pip use or a button on my remote to turn it on . Perhaps vu calls it by another name ?
Picture in picture is great for viewing a small screen on top of the regular viewed channel.
How can I use this on my VU+ ULTIMO 4K ? I AM USING OPEN ATV 6.0
any help appreciated ; wworps [ NICK ]
Another thing , while recording a channel , i cannot view other channels . I have 2 tuners set up and tuner A to auto and tuner B for recordings . Only the channel being recorded can be seen.
I understand that i have a disec switch set up and both channels need to be from the same SAT.
Even trying both from astra , channels won't play while recording . What am I doing wrong ?
We don´t support OpenATV images. We just give support for:
  • BlackHole images
  • Open BlackHole Images
For further party images, you must ask for support at the board to the correspondent image ( in your case OpenATV board ).
I hadn't noticed the part about OpenATV. I tried it in the past, just for curiosity but, as for every other images I've tried so far, I can tell you I've never found an image better than BH or OBH, I promise you.
As you are new at VU+, I suggest to try, for instance, OBH. ;)
Don´t bother with it, anyway, you have given feedback to user.
thanks
