Vu Ultimo BH2081 - Kodi Installation Questions
nsharma
Hi,
I wonder if you can please help or point me in the right direction regarding the questions below relating to Vu Ultimo receiver running BH2081:-
- If there is particular version of the Kodi plugin which needs to be installed onto the receiver from the ******** plugin listings?
- Once installed, what are the best configuration settings to be used for Kodi?
- What are the recommended file links to be used for Kodi?
Many thanks in advance, for all your help.
With kind regards.
Hi,
With kind regards.
No ******** supported or welcome here.
Thread closed.
