Vu+ Ultimo Hyprid tuner dvb-c2/dvb-t?
Jeffi
Hi guys,
Can someone please tell me for sure, does vu+ hyprid tuner work on dvb-t2 transmissions ot not.
It seems that it works well on HD content on our Anvia cable provider here in Finland, but when i scan for terrestrial content, it can't find any HD channels. I have added frequencies manually to terrestrial.xml and tried to scam manually, but result is the same. Am i missing something here or is it just that this tuner is really dvb-c2/dvb-t compatible and dont have support for dvb-t2 transmissions?
Thanks in advance.
J
Hi guys,
Thanks in advance.
J
DVB-T2 services cannot be tuned with internal DVB-T/C Vu+ hybrid tuners.
Thanks for the answer. So is it a hardware or a software issue and why is it possible to view dvb-c2 transmissions with the same hybrid tuner? In cable i get all HD channels.
J
You can tune with sucess DVB-C2 freqs with internal tuner?
In my country there isn't DVB-C :( and I cannot make direct tests.
About DVB-T and DVB-T2: some tuners can tune both frontends but it's needed something at driver level. Actually, Vu+ DVB-T tuner can only tune 1st generation DVB-T freqs.
Yes, in cable I get all SD and HD channels working with the same tuner, thats why i was wondering why does they call it dvb-c and not dvb-c2.
My cable provider here in Finland is Anvia and i tested on yleHD, NelonenHD, MTV3HD, SVT1HD, EurosportHD, BBC HD, Silver HD, Discovery HD, MTV Live HD, Food Network HD and HighTV 3D. All works well with hyprid tuner.
Will someone do something about it in the future to make a support dvb-t2 protocol/freq's, maybe new tuner or something or should i just use usb tuner?
What's the best usb dvb-t2 tuner you recommend for vu+ ultimo? I assume ZAP time and CPU usage wont be the same as being using hw tuners?
J
