hi guys i just tried to put some add ons on my box restarted it now its in a loop,i tried flashing with usb and put the image on by serial port but no joy,does anyone know how to fix this.
With a full reflash you should solve your problems.
Remeber to remove ALL USB devices connected and keep connected the only USB flashdrive with the image you want to re-flash.
Also, pay attention if you have full backups stored on HDD: the must be moved outside your box OR rename "vuplus" folder on your hDD.
