Vu Ultimo occasionally loosing channels
ruxu
Our Ultimo is a couple of months old and loaded with Black Hole 1.7.6, Cool TV Guide v.6.0 and EMC v.3.0.0. It has three terrestial receiver cards.
For about 6 weeks everything worked perfectly but now it has started to occasionally mix up and loose the TV channels. When this happens a text "The channel service ID can not be found in the Program Association Table" (translated from the Finnish text) is shown and the wrong channel is shown or doesn't change at all.
Most annoying is that this can happen also when you have timed recordings. Usually all recordings then shows only the text mentioned above and last only for seconds.
The problem is rectified when you shut down the box with a long push on the on/off button but then reoccures again after a while.
Anyone able to give a newbie a hint in the right direction?
