Vu+ ultimo problem with network
Hi all
I have a big problem with my setupbox
After i install blackhole 1.7.8 that problem starts
My network works in random mode, sometimes it works correctly and sometimes not.
After that i install 1.7.7 - 1.7.6 -1.7.5 and original image to but the problem is exist
I am very tired about this problem
Please help me
Sent from my iPad using Tapatalk HD
I use both connection lan and wifi but none of them works correctly
And i set DNS in manual mode but nothing happen
I would recommend to check the routers set ups, connection wires, the head of internet wire (connection head to STB),,,,,etc!
And disable DHCP,,,,chande to >> NO, and use only interface (It solved my problem)
This problem has nothing to do with the BH Image!
RgdZ
a911
Hi all
Please help me
hi i have some problem with this image i use lan connection you know i found the problem the ethernet port ultimo is blinking faster i just pool out the cable and fix back then work again
I use a fixed address and wire connection
and never have a problem with network.
The same goes for Wlan with orginal VU+ Wifi.
I use a fixed address and never have a problem with network.
thanks for your attention
finally i reset my modem and i set it again, after that my setup box works correctly with network.
thanks
thanks thanks
