VU+ Ultimo WLAN
Laserlinse
Hallo I´m a new Member from Germany
I have Problems with my WLAN Setup
I was testing two WLAN Sticks and in the end i have the Massage I can not generet passphrase
The Sticks are working on my PC korrektly
With the old AAF open Image 2011/10/24 the are working ( i must give them the and fix IP but the working ) but I dont like this Image , it is too difficult
what can , or what I must do??? Please help me
Sorry obout my misteks
Matrix10
Well I think you got the original VuPlus WLAN USB dongle ??
It works perfectly with my router 144 Mb/s
As you can see on my pictures.
You can use FIX IP but also DHCP,
both methods work.
You must not connect the USB stick and WLAN dongle on the back connectors together
because it may interfere with one another.
So if you use a USB stick.
First connect only Wlan dongle
and configure as in my shots/pictures.
If your wlan working you can connect agn USB stick but not on the back connectors together.
  • Like
Reactions: Ev0
Laserlinse
Yes I use the original Dongle and D-Link DWS 140, I work only with USB WLAN . My Vu turn on the Adapter, It is finding the Router , as the next DHCP or fix IP and at last write my WPS/WPA Key. Now I restart the Network . Than I have the Massage with booth Sticks. Can not generet Passphrase
When I turn of thr encryption ...... I becom the same error Massage
I do it like you with an different Result
Shiro
BH-C
Have you tryed to use WPA/WPA2 protocol with a simply password like
A893FG8KL
just to know if it works in this way
Laserlinse
Yes I was trying with 8 Numbers and an mixd version. Why it dosn´t work with the WPS Bottom on the stick ??
Matrix10
Check the configuration of your router.
There must be a problem.
It is probably included some protocol
that does not support VU driver.
I think you have to use only WPA2,aes
so test different configurations in your router ??
and test first with VUplus wlan dongle.
This dongle working 100%
Exposure
I have the same issue (Cannot generate passphrase). This is with the VTI image though, haven't tried other images yet.
Laserlinse
I was testing Open AAF; VIX; VTI 4,0; Black Hole 167 ; BH 167 Beta 3 ; BH170, and it´s on every image the theme result ( Cannot generate passphrase)
Now i´m not the only one any more. In my german VU+ Support Forum are many ueser with the same problem. I think it´s the driver.
angelofsky1980
BlackHole Driver Specialist
We are working on it.
Please specify what wifi adapter you are using.
Matrix10
Wi-Fi Protected Setup Status: Unconfigured
Network Name (SSID): Maxxxxx
Security: WPA2-Personal
Wireless Passphrase: *************
Most problems that you specify is related to WPS
disable wps or left not configured in your router
and in some routers use manual configuration.
If your Wlan dongle has a WPS button
attempt to register with them in your router.
So read carefully Manuel from your router
and Help in the router.
We do not have in the VU box that I know software possibility of
Wi-Fi Protected Setup.
This is help info in my router.
Wi-Fi Protected Setup Option 1
An administrator can push the Wi-Fi Protected Setup button on the Basic Wireless Settings screen or the button on the front panel of the Gateway to allow a user to register a wireless client with the Gateway. The user needs to push the Wi-Fi Protected Setup software button on the client side at the same time as the Wi-Fi Protected Setup button is pushed on the Gateway. The connection will be automatically set up.
Wi-Fi Protected Setup Option 2
This is the most secure option for an administrator to register a user's wireless client with the Gateway. The user needs to give the administrator their Wi-Fi Protected Setup PIN number, which is found in the client Wi-Fi Protected Setup utility. After entering the client's Wi-Fi Protected Setup PIN number, the administrator registers the user. The user can then connect to the Gateway.
Wi-Fi Protected Setup Option 3
The Gateway's Wi-Fi Protected Setup PIN number is on the label on its bottom panel. Using any Wi-Fi Protected Setup client utility or Microsoft Vista, the user needs to enter the Gateway's Wi-Fi Protected Setup PIN number into the client device.
Laserlinse
Now i have zoc telnet downloadet and here is the result
Vuplus 2.2.0 + BlackHole 1.7.0 vuultimo
vuultimo login:
vuultimo login: root
root@vuultimo:~#
root@vuultimo:~# cat /proc/bus/usb/devices
T: Bus=04 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 2
B: Alloc= 0/900 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 1.10 Cls=09(hub ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=1d6b ProdID=0001 Rev= 3.01
S: Manufacturer=Linux 3.1.1 ohci_hcd
S: Product=Broadcom STB OHCI
S: SerialNumber=ohci_hcd
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr= 0mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
E: Ad=81(I) Atr=03(Int.) MxPS= 2 Ivl=255ms
T: Bus=03 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 2
T: Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 2
B: Alloc= 0/800 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=1d6b ProdID=0002 Rev= 3.01
S: Manufacturer=Linux 3.1.1 ehci_hcd
S: Product=Broadcom STB EHCI
S: SerialNumber=ehci_hcd
E: Ad=81(I) Atr=03(Int.) MxPS= 4 Ivl=256ms
T: Bus=02 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=0bda ProdID=8178 Rev= 2.00
S: Manufacturer=Realtek
S: Product=802.11n WLAN Adapter
S: SerialNumber=00e04c000001
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 4 Cls=ff(vend.) Sub=ff Prot=ff Driver=rtl8192cu
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=84(I) Atr=03(Int.) MxPS= 64 Ivl=125us
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 2
root@vuultimo:~# > cat /proc/bus/usb/devices
Laserlinse
Now I have a WLAN connection !
The SSID of my Router was FRITZ!Box Fon WLAN 7390 , I was changing the name to FRITZBox7390 and it works 100%
I was removing Space and !
:yahoo:Laserlinse
helmy
On exploring the BH image, I found it difficult to configure the wireless connection. I put all the details of the settings but yet is not connected. The system cannot find the wireless network or IP address or Nameserver. The system crashes (S/W Problem) when I scan the wireless networks and prevent me from editing any settings. Please advise.​
angelofsky1980
No crashlog = no help
