VU+ universal remote control code?
radja
Hi everyone
I have Universal remote controller. In manual for it don't have VU+.
Did know which remote control code is for Universal remote controller?
I'm try some codes, but unsuccessful.
I hope you know what I need.
No other devices use the same IR codes as the Vu+'s boxes.
So if you couldn't find a preprogrammed code for your Vu+ model, then you can only resort to code learning from the original remote.
But consider that the Vu+'s remotes use the toggle bit for repetitive commands , so you'll find a lot of problems to use the learned IR codes of the arrow k.eys.
