VU+ UNO 4k and mosaic on HD-channels
matkoh
Hello.
I have just bought me an VU+ Uno4k, and trying BlackHole, using Swedish CanalDigital and Viasat, but there is impossible to watch any HD-channel, only mosaic and blurred image. The signalstrenght is 99% (17 db), and all of my other boxes on the same switch works just fine. I have also tested VTI, and then HD-channels works OK.
Any suggestion ?
A try could be to have a look at Common Interface settings, particularly at the "Hight bitrate" setting. If it is set to "NO" switch to YES and see what happens.
