Vu uno 4K Flash problem
Try another USB stick
Use the USB port on the left.
The USB stick must be formatted with Fat 32
Before every test.
Unzip all of the Zip file and copy it to USB stik.
Turn off the receiver.
Connect USB stick.
Turn on the receiver.
The rhythm of the light indicates the beginning and end of the flash process.
Before every test.
Connect USB stick.
Thanks you for your great support for me.
Thanks you, I am going to trying for your advice. Thanks you.
