Hi everyone
I am new to Linux STB's, as I have been previously using non linux STB's.
I have narrowed down the model to Vu+ Uno 4k.
In this connection I have a few points to get clarified before purchase.
1. Is the Linux OS and the image 2 different things or is the same thing.
2. What is the manufacturers Linux OS on the Vu+ Uno 4k.
3. What is the manufacturers image on the Vu+ Uno 4k.
4. Why should you change to a new image.
5. What tuner is fitted as standard (dual FCB DVB S/S2" or the dual FCB DVB-C tuners)
6. With the dual FCB DVB S/S2 tuner fitted, can you connect 2 LNB's.
Best regards
Best regards
