Vu+ UNO 4K SE HDD bracket -> height problem!
dabezt
Where's explained that the detachable bracket for 2.5" HDD in the Vu+ Uno 4K SE not support disks with 12,5mm of height? Nowhere!
Found problems with toshiba toshiba mk1059gs that has 12,5mm height. The hdd + bracket doesn't 'enters' in the slot with the bracket. It seems it has to be 9 or 7 mm maximum.
It's not specified anywhere.
is there any bracket more 'thin' in order to fit the 12,5mm height hdd?
Thnx. cheers.
AlexWilMac
Moderator
Caddies (or "brackets") are not indispensable: they are needed just to keep the HDD steady. If you find a way to block the HDD, for instance by a double-sided sellotape, you won't need any caddy.
Also many laptops can't use 12,5mm HDDs...
