Vu Uno 4K Se satfinder plugin problem.
VLADI
Just get new Vu box & find out, when I start to change frequency of satellites on that plugin box go to error with green screen & restart every time I try to do that, but when I just scan for satellites it find transponders on manual scan.
Don't know what is going on.
Anyone can point me to right direction how to fix that problem.
VLADI
The perfect manual searches.
The ratio of tp/frequencies in commercial satellites does not change (only the SR / FEC).
The blind search of the problems in these teams/receivers, end of the joke.
If you want to update the file satellites.xml from DreamBoxEdit or use the web that I indicate and update by hand modifying the file.
Las busquedas manuales perfectas.
La relacion de tp/frecuencias en satelites comerciales no cambia (solo el SR/FEC).
La busqueda ciega da problemas en estos equipos/receptores, fin del chiste.
Si quieres actualizar el fichero satellites.xml desde DreamBoxEdit o usa las web que indico y actualiza a mano modificando el fichero.
http://satellites-xml.org/
https://satellites-xml.eu/
