VU+ Uno 4K SR DVB-C Issue
Marcos Martins
Hi Guys,
I'm using Uno 4K in Brazil, with DVB-C network.
The local cable operator uses 5217 as Symbol Rate, but when I perform a NIT search, it finds all the frequencies, but SR 5217 doesn't work!
If I change SR from 5217 to 6900 it finds the channels, but I have to do this mannually, with NIT search disabled.
I had to create a cables.xml file with the "wrong" SR from Brazil, so I can be able to make channel scan succesfully, but it takes too long, since a lot of frequencies have no signal.
Is that possible to fix his SR issue with DVB-C in next releases?
Sorry if this is not the right place to tell my problem.
BR,
MM
