Vu+ Uno and DiSEqC 1.1
beigas
Please help with setting up Vu+ Uno with DiSEqC 1.1. I'm newbie with vu+ configuration, still have used proprietary tuners, and all was fine.
Layout: tuner + DiSEqC with 10 ports, 8 in use; it worked fine with Amiko Mini tuner and before with Digiline 7000.
Issue: whatever I set up a satellite, I can find only first 4 ports. I assume this means I have enabled only 1.0. Even if in configuration (advanced) I have enabled 1.1. I tried a bunch of methods found in forums and manuals but didn't succeed. satellites.xml is up to date.
Is there available any howto or step-by-step instructions how to really enable DiSEqC 1.1?
Problem solved, an issue cause was wrong "command order" in configuration, must set "uncommitted" as first
