VU+UNO and USB TUNER WINTV MINISTICK
mrcapitan
Hello friends!
My WINTV-ministick-HD Hauppage USB Tuner is not working on blackhole images on my VU+UNO.
When I try to install driver, this message appears: 'This tuner isn't compatible with your box'.
Anyone can say to me when will be solved?
Thanks a lot.
mrcapitan
First of everything,
Thank you for your interest to solve the problem that we have all the owners of this usb Tuner. I am sure that this one will not be difficult to you to be able to solve incompatibility, as you were doing some time ago with volar black hd and vu+duo o.e 6 images.
Here you have the images of the tuner and the selected driver in screen which doesn't work. If you need more information, he would be grateful to you that you were saying it, since when before having the VU+UNO, I had the VU+DUO and me I bought this one tuner because in those moments there was not working the volarblack that had, and neither now works this one with vu+uno that I have just bought.
Regards and thank you very much.
el_zari
BH Lover
Angelo, last week, I post the log of WinTv Stick.....
Regards from Spain
Thanks very much again!!
mrcapitan
Hello Angelofsky1980...
Have you detected the mistake on this driver?
¿Do you think you will can solve it soon?
I am waiting your solution...
Thanks very much..
angelofsky1980
BlackHole Driver Specialist
Thanks very much..
In these weeks I've received my new notebook and I will prepare it to compile drivers for Vu+ boxes.
On the log reported from el_zari there are some useful infos.
mrcapitan
OHHH no!
I can't wait some weeks more.... My wife and my son are going to kill me!!! I spend more money on other vu+ receiver and she can't see terrestrial channels...
Angelofsky1980, if you don't want to go to a burial, please, arrange it soon, please! jejeje....
I am sure that this is a small modification because in the VU+DUO this was working.
Thank you for your time and your attention.
el_zari
BH Lover
Mr Capitan....are you alive yet? xDDDDDD
:confused:
Angelo: have you received your notebook? are you on vacations? ;) Any notive from wintv new driver?
Regards from Spain
angelofsky1980
:confused:
Regards from Spain
I've received it two weeks ago and I've configured it with Win7 Pro + Ubuntu 11.04 :)
I don't have MiniStick but I have wrote to my colleague Admin who have this kind of device to make direct tests and report problems with other devices.
mrcapitan
Hello angelo...
Do you can give me a date to solve the issue with this Usb Tuner drivers and vu+uno??
We are waiting a lot of weeks
Thanks
angelofsky1980
Is it solved on new blackhole 1.6.5 ? How long to wait?
Dear friend, the drivers are not changed from BH 1.6.4 and 1.6.5.
I've bought a Ministick to make direct tests on this device this saturday. The only thing I've detected is a little problem with Uno. On Duo and Solo this device works correctly.
When the problem is solved? As soon as possible.
