Vu+uno Black hole -reboot system/plugin
bojja
Is there any plugin or somethingto do else to time my receiver to do reboot by itself from time to time?Thanks
If I've correctly understood your question I think it's possible with cron, but I don't know the exact syntax.
With cron you can plan any command, like reboot, at a specific date/time/hour.
P.S.: in the blue panel you can find cron manager that's what you need. ;)
