VU UNO death after upgrade
KFL
Version before upgrade was 0.6.0.20.
Today (9.dec2016) I made online upgrade my VU UNO OpenBH.
Uno restarted and everything seems to be working fine...but.
Later I power off (standby). It was last action from UNO.
After I press power on, UNO keep showing Starting and nothing happens. RED led on.
Hard power off/on - nothing. Same problem.
ARRRRRGGHHHHHHH!!!!!!!!!!!!!
USB reflash: Works again.....just moment, I try online update....
HAHAHAHHA Same problem again!!!! Just Starting and black screen!!!!
Do not make online update, something is bad in today's release!!!
arj,lf.;kughlcajvuiathot7ogfqilfjyqrigcjgfyricfhqrifhrmchfqcfhryfhqrrmirlqfi.;hbfyrlacfhknfh
Hello,
Same problem with me!
Last night I wanted to make updates (~80). As usual green -> yellow -> BH update.
Crash !! Unable to restart. I handed the original image 0.6, redo the updates. The same result.
Attempted via telnet opkg update, upgrade. The same result.
I stayed at the June version Even adding a skin crash!
Thanks
Same problem reported by users od Solo2/Duo2.
BH Team: where is problem? Do something, make some anoncemnent(warning) or other message what is happened.
You probably ran out of space in flash.
For Gen 1 boxes (excluding the ultimo).
You are better off using OpenMultiboot (install obh in flash, with nothing extra added to the image, then install OMB onto your usb stick and then install the image into OMB and run that as your main image).
Ciao Evo
Gentilmente puoi tradurre in italiano che non ho capito bene
Probabilmente ha esaurito lo spazio in flash.
Per Gen 1 scatole (escluso il Ultimo).
Si sta meglio con OpenMultiboot (installare OBH in Flash, con niente extra aggiunto all'immagine, quindi installare OMB sulla vostra chiavetta USB e quindi installare l'immagine in OMB ed eseguire che come immagine principale).
Tradotto da Google
Tradotto da Google
Da gennaio escuso il vu ultimo
Dovranno flashare la open black hole in multiboot su chiavetta usb e metterla come immagine principale
Se ho capito bene
Se ho capito bene
In primo luogo mettere un'immagine fresca OBH in Flash, ma non installare eventuali aggiornamenti o aggiungere nulla all'immagine (mantenerlo il più piccolo possibile).
Quindi installare OpenMultiboot al vostro USB.
Quindi installare OBH di nuovo, ma questa volta in OpenMultiboot, e quando l'installazione è completata, l'avvio in quell'immagine, e l'uso che, al posto dell'immagine in flash.
In questo modo si dovrebbe mai a corto di spazio flash.
Tradotto con Google.
The issue has been identified, there has been a recent change in the OE-A git, and this has broken the online update for the exisiting OBH builds, and we believe this will be a problem for all current oe-a images.
New full flash files have been posted, please reflash your box with the latest builds.
Thank you for answer. I test it later.
