Hi All,
Need help to repair (Timers.XML).
Been having a record to External HDD problem, each time I mount
the USB/HDD the Uno crashes after reboot, Blue screen, then shuts
down. I then receive error (The timer File (timers.XML) is currupt
and could not be loaded). Can I fix this with an Editor, or do I need
some other Tool.
Using B/hole 1.7.2.
Have backed Up settings to PC HDD with (VuSettingsBackup_V13.
But It will have the currupt Timer file in It.
PS, Have had the USB HDD recording before faulty Timer problem.
Thank's for any Help, BF.
some other Tool.
Using B/hole 1.7.2.
