vu+uno imajlari
levi
Moderator
Neues VTi "Vu+uno Team Image" - v. 5.0.0 - 11.12.2012 OE 1.6
CHANGELOG
* dvbapp2: 11.12.2012
* drivers: 25.10.2012 (09.11.2012 Solo²)
* plugins: 11.12.2012
--> changes from Vu+ : http://code.vuplus.com
CHANGELOG VTi
* added to image
- AutoShutDown plugin
* added to download feed
- EMC 3.6.6beta (2012-12-05)
* updated packages
- openvpn (ver. 2.2.2)
- switch WLAN drivers from rt3070 to rt5572
- update WLAN drivers r8192cu (3.4.4.4749-20120730)
* kernel
- added kernel modules for netfilter dscp target and mangle modules
* dvbapp2
- show icons in timer list
- enable REC button for managing all timers (not only instant records)
- press REC button long for showing a list of all running timers
- enable REC button functions at playback (MoviePlayer e.g. EMC)
- add option for deleting finished timers automatically
- add option to priories feed updates (opkg option --force-overwrite)
- language menu shows only installed languages
- VTiZerO and VTi BackupSuite integrated into startup wizard
- package split for dvbapp2 package to reduce required update space
- bugfix "silent rec mode" (timer action "DeepStandby" works again"
- update cs translation (THX @Roxy)
* VTiPanel
- restructure of menu
- VTiZerO: option to recover removed packages
- image backup: backup is not saved to /media/hdd anymore by default (only to configured backup path)
- show hdd temperature independent of device /dev/sdX
