vu uno nameserver
nikdes
when i doing a test to my network it says nameserver unverified and i cant connect on internet..how can i fix it?
i want to do my network wizard manual...how can i find the correct ip it asks.......ip adress?///netmask is 255.255.255.0 gateway?
Dear Friend.
First let all to automatic, so you can verify all is OK with router.
Then change DHCP to manual and change settings( like IP of the box).
Usually Name server is same as routers IP.
