Request VU + UNO problem with clock
artan
hello
Black Hole 2.0.3 Hyperspace
I've got a problem
The time of my vu+ uno is wrong. It's around 25minutes ahead of time.
I made ​​search on Google about this problem and tried many solutions for this, but none of them worked.
So it's a problem of your provider. Uno doesn't have internal clock. It picks time and date from channel you are receiving.
I do not know the first time that this happened
I leave it to the sky again I am not changing remains 25 minutes behind
Switch to other channel (different provider), and try to reboot. Vu+ really doesn't have internal clock.
To note for others users sometimes reboot is not enough
it is necessary to completely shut down box
and re-turn on on a good transponder.
Interesting! If the box really doesn't have an internal clock, then how it wakes up from deep standby on time, boots and began to record or something set on timer? There is no transponder signal reception and no image or software running on deep standby!
In deep standby is still powered. When you turn it off (rear switch), memory of clock is erased. You don't have battery powered internal clock or RTC like on PC.
So, it doesn't have backup buttery, but internal clock should be present and running, am I right?
I do not know but once restored the clock to TV, everything returned to normal and to vuuno
[ I made ​​many attempts in different transponder, as Sky Italia and Sky de, and reboot many times, but without result ]
but as I mentioned with the clock change to TV, everything returned to normal
