Vu Uno problema doppo led rosso....
titetolo
Ho fatto la procedura della jtag e finalmente e tornato in vita il Vu Uno, ma riesco a fare il flash da usb , ho provato diverse immagini ( anche l'originale), e rimane sulla schermata iniziale della impostazione della lingua, e non me da la possibilità di interagire con il telecomando . Ho aperto Hyperterminal e mi da questo log , mi potette aiutare.....
[SC]: registered sci1
system_time_set wakeup mode get
system_time_set wakeup mode get 0xc4
fpga update driver loaded
Startting the hotplug events dispatcher
udevd (101): /proc/101/oom_adj is deprecated, please use /proc/101/oom_score_adj
instead.
Synthesizing the initial hotplug events
Waiting for /dev to be fully populated
udevd-event[232]: node_symlink: rename(/dev/fb.udev-tmp, /dev/fb) failed: Is a d
irectory
done
driver is installed
mount: mounting /dev/sda1 on /media/hdd failed: No such file or directory
/dev/sda: No such file or directory
cat: can't open '/etc/videomode': No such file or directory
[VID]: VIDEO_SET_STREAMTYPE 0
[VID]: VIDEO_SELECT_SOURCE 1
[VID]: VIDEO_PLAY 1 2 0
[VID]: VIDEO_CONTINUE 1 1
[VID]: VIDEO_CLEAR_BUFFER 1 1 0
ldconfig: Can't open configuration file /etc/ld.so.conf: No such file or directo
ry
[VID]: VIDEO_STOP 0 1
[VID]: VIDEO_SELECT_SOURCE 0
Configuring dbus
Adding system startup for /etc/init.d/dbus-1.
Configuring wpa-supplicant
Configuring ppp
Configuring r8192cu
Configuring avahi-daemon
Adding system startup for /etc/init.d/avahi-daemon.
Configuring enigma2
Configuring update-modules
Configuring vsftpd
Adding system startup for /etc/init.d/vsftpd.
Configuring vuplus-bootlogo
Setting up IP spoofing protection: rp_filter.
Configuring network interfaces... bcmemac: eth0 NIC Link is Down
eth0 no wireless extensions.
udhcpc (v1.15.3) started
Sending discover...
Sending discover...
Sending discover...
No lease, forking to background
done.
Starting system message bus: dbus.
Creating Dropbear SSH server RSA host key.
Will output 1024 bit rsa secret key to '/etc/dropbear/dropbear_rsa_host_key'
Generating key, this may take a while...
Public key portion is:
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAAAgwCDUFu8HXKUY/mpY/63tfOoZcCJ6aPYaUfeKH3u+qCw
Xwk2yvOqUltDZ7D4BT52WsuVamEbBiZAop8ZmcTWKMQXtpt+FVodGZ6OpklfH34PEwrxRU6qOgYRvjMh
PdBy6YOf+OJfoUUP0vAr3dCAa2catOWNB7TN1ein+MrD6qdBFsLZ root@vuuno
Fingerprint: md5 33:cc:59:07:b6:a6:a2:ec:bf:08:8a:48:a2:85:94:76
Starting Dropbear SSH server: dropbear.
Starting internet superserver: inetd.
Starting openvpn:.
Starting syslogd/klogd: done
* starting FTP Server: vsftpd... done.
Starting automounter: done.
[ ok ]rting Avahi mDNS/DNS-SD Daemon: avahi-daemon
setenv('prefix', '/usr', 0)
setenv('exec_prefix', '/usr', 0)
setenv('bindir', '/usr/bin', 0)
setenv('sbindir', '/usr/sbin', 0)
setenv('libexecdir', '/usr/libexec', 0)
setenv('datarootdir', '${prefix}/share', 0)
setenv('datadir', '/usr/share', 0)
setenv('sysconfdir', '/etc', 0)
setenv('sharedstatedir', '/com', 0)
setenv('localstatedir', '/var', 0)
setenv('libdir', '/usr/lib', 0)
setenv('localedir', '${datarootdir}/locale', 0)
setenv('prefix', '/usr', 1)
setenv('exec_prefix', '/usr', 1)
setenv('bindir', '/usr/bin', 1)
setenv('sbindir', '/usr/sbin', 1)
setenv('libexecdir', '/usr/libexec', 1)
setenv('datarootdir', '/usr/share', 1)
setenv('datadir', '/usr/share', 1)
setenv('sysconfdir', '/etc', 1)
setenv('sharedstatedir', '/com', 1)
setenv('localstatedir', '/var', 1)
setenv('libdir', '/usr/lib', 1)
setenv('localedir', '/usr/share/locale', 1)
resolve: resolve ${datadir}/enigma2/encoding.conf
resolve: -> /usr/share/enigma2/encoding.conf
resolve: resolve ${libdir}/enigma2/python
resolve: -> /usr/lib/enigma2/python
PYTHONPATH: /usr/lib/enigma2/python
+ (1) Background File Eraser
+ (8) graphics acceleration manager
+ (9) GFBDC
12150k video mem
- double buffering available!
5670kB available[LCD]: unknown cmd 0x1015
for acceleration surfaces.
resolution: 720 x 576 x 32 (stride: 5760)
+ (9) gLCDDC
found OLED display!
lcd buffer 0x6ceda8 8448 bytes, stride 132
+ (9) Font Render Class
[FONT] initializing lib...
[FONT] loading fonts...
[FONT] Intializing font cache, using max. 4MB...
+ (10) gRC
RC thread created successfully
+ (15) eWindowStyleManager
+ (20) DVB-CI UI
+ (20) Hdmi CEC driver
+ (20) UHF Modulator
couldnt open [CI]:ci_dev_open
[CI]:entering.. A NEXUS_DvbCi_Open
+ (20) RC Input[CI]:NEXUS_DvbCi_Open done..
layer
+ (20) m[CI]:Installing callbacks
isc options
+ ([CI]:Forcing card check
20) AVSwitch Dri[CI]:Card insertion status changed
ver
+ (21) inpu[CI]:entering.. B NEXUS_DvbCi_Open
Input device "d[CI]:Installing callbacks
reambox advanced[CI]:Forcing card check
remote control [CI]:Card B insertion status changed
(native)" is not a keyboard.
Found 1 input devices!
+ (21) Con[CI]: CI interface initialised
sole RC Driver
failed to open /dev/tty0
+ (30) eActionMap
+ (35) CI Slots
sc[CI]:ci1_dev_open
anning for common interfaces..
CI Slot 0 setSource(0)
CI Slot 1 setSource(0)
eDVBCIInterfaces->setInputSource(0, 0)
eDVBCIInterfaces->setInputSource(1, 1)
cannot open /proc/stb/tsmux/input2
cannot open /proc/stb/tsmux/input3
done, found 2 common interface slots
+ (40) eServiceCenter
settings instance.
+ (41) eServiceFactoryM2TS
+ (41) eServiceFactoryMP3
+ (41) eServiceFactoryFS
+ (41) eServiceFactoryDVB
reached rl 70
resolve: resolve ${sysconfdir}/enigma2/lamedb
resolve: -> /etc/enigma2/lamedb
---- opening lame channel db
can't open /etc/enigma2/lamedb: No such file or directory
scanning for frontends..
opening frontend 0
detected satellite frontend
FE_ENABLE_HIGH_LNB_VOLTAGE: Operation not supported
close frontend 0
found 1 adapter, 1 frontends(1 sim) and 5 demux, boxtype 4
RTC not ready... wait for transponder time
[EPGC] Initialized EPGCache (wait for setCacheFile call now)
resolve: resolve ${datadir}/enigma2/skin_default/pal.png
resolve: -> /usr/share/enigma2/skin_default/pal.png
Loading spinners...
resolve: resolve ${datadir}/enigma2/skin_default/spinner/wait1.png
resolve: -> /usr/share/enigma2/skin_default/spinner/wait1.png
resolve: resolve ${datadir}/enigma2/skin_default/spinner/wait2.png
resolve: -> /usr/share/enigma2/skin_default/spinner/wait2.png
resolve: resolve ${datadir}/enigma2/skin_default/spinner/wait3.png
resolve: -> /usr/share/enigma2/skin_default/spinner/wait3.png
resolve: resolve ${datadir}/enigma2/skin_default/spinner/wait4.png
resolve: -> /usr/share/enigma2/skin_default/spinner/wait4.png
resolve: resolve ${datadir}/enigma2/skin_default/spinner/wait5.png
resolve: -> /usr/share/enigma2/skin_default/spinner/wait5.png
found 4 spinner!
executing main
setIoPrio best-effort level 3 ok
resolve: resolve ${libdir}/enigma2/python/mytest.py
resolve: -> /usr/lib/enigma2/python/mytest.py
resolve: -> /etc/
resolve: -> /etc/
resolve: resolve ${datadir}/fonts/
resolve: -> /usr/share/fonts/
resolve: resolve ${libdir}/enigma2/python/Plugins/
resolve: -> /usr/lib/enigma2/python/Plugins/
resolve: resolve ${datadir}/enigma2/po/
resolve: -> /usr/share/enigma2/po/
resolve: resolve ${sysconfdir}/enigma2/playlist/
resolve: -> /etc/enigma2/playlist/
resolve: resolve ${datadir}/enigma2/defaults/
resolve: -> /usr/share/enigma2/defaults/
resolve: resolve ${datadir}/enigma2/dealer
resolve: -> /usr/share/enigma2/dealer
resolve: resolve ${datadir}/meta
resolve: -> /usr/share/meta
no profile data available
enumerating block devices...
found block device 'loop0': blacklisted
found block device 'loop1': blacklisted
found block device 'loop2': blacklisted
found block device 'loop3': blacklisted
found block device 'loop4': blacklisted
found block device 'loop5': blacklisted
found block device 'loop6': blacklisted
found block device 'loop7': blacklisted
found block device 'mtdblock0': blacklisted
found block device 'mtdblock1': blacklisted
found block device 'mtdblock2': blacklisted
found block device 'mtdblock3': blacklisted
found block device 'mtdblock4': blacklisted
found block device 'mtdblock5': blacklisted
found block device 'mtdblock6': blacklisted
found block device 'mtdblock7': blacklisted
unable to load config ([Errno 2] No such file or directory: '/etc/enigma2/settin
gs'), assuming defaults...
not loading user skin: [Errno 2] No such file or directory: '/etc/enigma2/skin_
user.xml'
main thread is non-idle! display spinner!
menu_mainmenu
Preferred tag editor set to None
Reading satellites.xml
resolve: resolve ${datadir}/enigma2/unicable.xml
resolve: -> /usr/share/enigma2/unicable.xml
sec config cleared
setSlotInfo for dvb frontend 0 to slotid 0, descr Vuplus DVB-S NIM, need rotorwo
rkaround No, enabled No, DVB-S2 Yes
slot: 0 configmode: nothing
sec config completed
resolve: resolve ${datadir}/enigma2/setup.xml
resolve: -> /usr/share/enigma2/setup.xml
loading bouquet... /etc/enigma2/bouquets.tv
can't open /etc/enigma2/bouquets.tv: No such file or directory
recreate bouquets.tv
resolve: resolve ${sysconfdir}/enigma2/bouquets.tv
resolve: -> /etc/enigma2/bouquets.tv
loading bouquet... /etc/enigma2/bouquets.radio
can't open /etc/enigma2/bouquets.radio: No such file or directory
recreate bouquets.radio
resolve: resolve ${sysconfdir}/enigma2/bouquets.radio
resolve: -> /etc/enigma2/bouquets.radio
resolve: resolve ${sysconfdir}/enigma2/userbouquet.favourites.tv
resolve: -> /etc/enigma2/userbouquet.favourites.tv
resolve: resolve ${sysconfdir}/enigma2/userbouquet.favourites.radio
resolve: -> /etc/enigma2/userbouquet.favourites.radio
[eDVBLocalTimeHandler] enable sync local time with transponder time!
add dreampackage scanner plugin
added
Installing image defaults
Reading .info file /usr/share/enigma2/defaults/Dream/dm8000.info
prerequisites: {u'bcastsystem': ['DVB-S']}
prerequisites: {u'bcastsystem': ['DVB-C']}
prerequisites: {u'bcastsystem': ['DVB-T']}
Reading .info file /usr/share/enigma2/defaults/Dream/dm800.info
Reading .info file /usr/share/enigma2/defaults/Dream/dm7025.info
Reading .info file /usr/share/enigma2/defaults/Dream/dm500hd.info
Reading .info file /usr/share/enigma2/defaults/Dream/dm7020hd.info
Reading .info file /usr/share/enigma2/defaults/Dream/dm800se.info
prerequisites: {u'hardware': ['dm8000']}
prerequisites: {u'hardware': ['dm800']}
prerequisites: {u'hardware': ['dm7025']}
prerequisites: {u'hardware': ['dm500hd']}
prerequisites: {u'hardware': ['dm7020hd']}
prerequisites: {u'hardware': ['dm800se']}
self.packageslist: [({'prerequisites': {u'hardware': ['dm8000']}, 'attributes':
{u'config': [{'directory': '/usr/share/enigma2/defaults/Dream/', 'name': 'settin
gs.8000'}], u'favourites': [{'directory': '/usr/share/enigma2/defaults/Dream/',
'name': 'bouquets.tv'}, {'directory': '/usr/share/enigma2/defaults/Dream/hdbouqu
ets/', 'name': 'userbouquet.favourites.tv'}], 'filestype': 'directories', 'name'
: 'Dream Multimedia Default', 'author': 'Dream Multimedia GmbH'}}, '/usr/share/e
nigma2/defaults/Dream/dm8000.info')]
installing package with index 0 and name Dream Multimedia Default
currentAttributeIndex: 0
installing skin with index 0
currentAttributeIndex: 1
installing config with index 0
merging config: /usr/share/enigma2/defaults/Dream/ - settings.8000
installing config with index 1
currentAttributeIndex: 2
installing favourites with index 0
installing favourites: /usr/share/enigma2/defaults/Dream/ - bouquets.tv
loading bouquet... /etc/enigma2/userbouquet.favourites.tv
0 entries in Bouquet userbouquet.favourites.tv
1 entries in Bouquet bouquets.tv
loading bouquet... /etc/enigma2/userbouquet.favourites.radio
0 entries in Bouquet userbouquet.favourites.radio
1 entries in Bouquet bouquets.radio
installing favourites with index 1
installing favourites: /usr/share/enigma2/defaults/Dream/hdbouquets/ - userbou
quet.favourites.tv
117 entries in Bouquet userbouquet.favourites.tv
installing favourites with index 2
currentAttributeIndex: 3
currentAttributeIndex: 4
installing services with index 0
end of package reached
set status to DONE
installing done!
[FONT] adding font /usr/share/fonts/nmsbd.ttf...OK (Display)
4050kB available for acceleration surfaces.
resolution: 1280 x 720 x 32 (stride: 5760)
[FONT] adding font /usr/share/fonts/MyriadPro-Regular.otf...OK (Regular)
[FONT] adding font /usr/share/fonts/MyriadPro-Semibold.otf...OK (Semibold)
[FONT] adding font /usr/share/fonts/MyriadPro-SemiboldIt.otf...OK (Semiboldit)
[FONT] adding font /usr/share/fonts/lcd.ttf...OK (LCD)
[FONT] adding font /usr/share/fonts/ae_AlMateen.ttf...OK (Replacement)
[FONT] adding font /usr/share/fonts/tuxtxt.ttf...OK (Console)
[FONT] adding font /usr/share/fonts/nmsbd.ttf...OK (Subtitlefont)
[iInputDevices] getInputDevices <ERROR: ioctl(EVIOCGNAME): [Errno 25] Inappropr
iate ioctl for device >
cannot open /proc/stb/avs/0/input_choices
--> setting scaler_sharpness to: 0000000D
couldn't open /proc/stb/misc/12V_output
resolve: resolve ${datadir}/enigma2/keymap.xml
resolve: -> /usr/share/enigma2/keymap.xml
[ePopen] command: ip -o addr show dev eth0
setLCDBrightness 25
setLCDBrightness 127
resolve: resolve ${datadir}/keymaps/
resolve: -> /usr/share/keymaps/
Activating keymap: Keyboard English
[ePopen] command: loadkmap < /usr/share/keymaps/eng.kmap
Activating language English
language set to en_EN
FIXME: request for unknown slot
/usr/lib/python2.6/site-packages/gdata/tlslite/utils/cryptomath.py:9: Deprecatio
nWarning: the sha module is deprecated; use the hashlib module instead
import sha
<ManualFancontrol> setPWM to : 10
<ManualFancontrol> init : self.fanoffmode : OFF
<ManualFancontrol> init : config.plugins.manualfancontrols.pwmvalue.value : 10
[UIPositionSetup] write dst_left : 0
[UIPositionSetup] write dst_width : 720
[UIPositionSetup] write dst_top : 0
[UIPositionSetup] write dst_height : 576
<RemoteControlCode> Write Remote Control Code : 2
It's now Thu Jan 1 01:01:19 1970
[timer.py] next activation: 179 (in 99838 ms)
timers.xml not found!
[timer.py] next activation: 179 (in 99775 ms)
prepared cmd: echo 0 > /proc/stb/fp/mouse
prepared cmd: echo "copypsrc" > /proc/stb/fb/alpha_op
prepared cmd: echo "0x0" > /proc/stb/fb/alpha_value
prepared cmd: killall -15 arora
killall: arora: no process killed
[CrashReport] auto submit
[CrashReport] no crash-log
[EPGC] setCacheFile read/write epg data from/to '/hdd/epg.dat'
updateList
done
allocating new converter!
warning, skin is missing element arrowdown2 in <class 'Screens.LanguageSelection
.LanguageWizard'>
warning, skin is missing element wizard in <class 'Screens.LanguageSelection.Lan
guageWizard'>
updating language...
updateList
done
selectPic: arrowdown
selectPic: arrowup
setPixmapNum(0) failed! defined pixmaps: []
setValue 100
[AUD]: AUDIO_SET_MUTE 0
Setvolume: 100 1[AUD]: AUDIO_SET_MIXER -837009936
00 (raw)
Setvol[AUD]: AUDIO_SET_MIXER : amixl 0, amixr 0
[AUD]: AUDIO_SET_MIXER : next left volume 0, right volume 0
[AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
00 (raw)
child has terminated
pipes closed
pipes closed
[ePopen] command: route -n | grep eth0
poll: unhandled POLLERR/HUP/NVAL for fd 28(16)
poll: unhandled POLLERR/HUP/NVAL for fd 30(17)
pipes closed
[Network.py] resolv.conf - opening failed
nameservers: []
read configured interface: {'lo': {'dhcp': False}, 'eth0': {'dhcp': True}}
self.ifaces after loading: {'eth0': {'preup': False, 'predown': False, 'ip': [0,
0, 0, 0], 'up': True, 'mac': '00:1d:ec:03:ff:72', 'dhcp': True, 'netmask': [0,
0, 0, 0], 'gateway': [0, 0, 0, 0]}}
poll: unhandled POLLERR/HUP/NVAL for fd 26(16)
bcm7413: hotplug_callback():
Hotplug - status.connected 1
Hotplug - connecting HDMI to display 0xf
Hotplug - status.connected 0
Hotplug - Disconnecting HDMI from display
Hotplug - connecting HDMI to display 0xe
It's now Thu Jan 1 01:02:59 1970
[timer.py] next activation: 279 (in 99998 ms)
[timer.py] next activation: 279 (in 99997 ms)
bcmemac: eth0 NIC Link is Up 100 Mbps Full Duplex
It's now Thu Jan 1 01:04:39 1970
[timer.py] next activation: 379 (in 99999 ms)
[timer.py] next activation: 379 (in 99997 ms)
Grazie mille per l'aiuto , ma io tengo premuto 2 e 7 ma led non si accende e non cambia niente ....Ho provato anche su vuduo e anche li non si accende led. Non so dove sbaglio...
Strano, sui telecomandi originali dovrebbe funzionare tranquillamente.
Prova a tenere schiacciati contemporaneamente i tasti un po' piu' a lungo, eventualmente prova a mettere delle batterie nuove.
Niente , uguale cambiando le batterie, mi sembra strano , via seriale con lo stesso versione ( ovviamente file nfi ), va fino a 40% poi si blocca per errore, non riesco ad aggiornare via seriale ( anche firmware l'originale) , solo da usb.....
