Vu Uno starting problem ... please help
osamaharam
My Uno stopped at starting and it does not response to any new image that i put it on usb
I tried to install new image by Vu utility and serial cable and it failed
there is the log from terminal for more details
BCM74130011
012
K1
K2
K3
K4
K5
Shmoo Version=3.8
DDR Freq=0x0000018C
%00000001%
RC1=00000004
WC1=FFFFFFF2
RC2=00000018
WC2=0000003A
RC3=0000000E
WC3=FFFFFFF2
RC4=0000000E
WC4=0000003E
NWC=00000018
RC5=00000004
WC5=00000018
RC6=00000018
WC6=00000018
NRC=0000000E
RW=00000015
WW=0000004D
G=00000000 R=0000000E W=00000018
BL=00000000
RC1=00000001
RC2=00000013
BL=00000001
RC1=00000002
RC2=00000012
BL=00000002
RC1=00000002
RC2=00000015
BL=00000003
RC1=00000003
RC2=00000012
BL=00000004
RC1=00000004
RC2=00000017
BL=00000005
RC1=00000005
RC2=00000018
BL=00000006
RC1=00000001
RC2=00000014
BL=00000007
RC1=00000003
RC2=00000015
3
COPY CODE
A567
BCM97413B1 CFE v2.26, CFE core v2.12, Endian Mode: Little
Build Date: Thu Jun 16 09:50:22 2011 (doliyu@doliyu_note)
Copyright (C) Broadcom Corporation.
writing vfd
New NAND flash at 18000000 offset 00000000 size 116736KB
New NAND flash at 18000000 offset 07200000 size 4096KB
New NAND flash at 18000000 offset 07600000 size 4096KB
New NAND flash at 18000000 offset 07A00000 size 2048KB
New NAND flash at 18000000 offset 07C00000 size 1024KB
New NAND flash at 18000000 offset 07D00000 size 512KB
New NAND flash at 18000000 offset 07D80000 size 512KB
New NAND flash at 18000000 offset 07E00000 size 1024KB
New NAND flash at 18000000 offset 07F00000 size 1024KB
DDR Freq: 396MHz
CPU speed: 405MHz
Memory Config: 64-bit UMA
Device Tech: 1Gb
Total memory: 512MB
Boot Device: NAND
Total flash: 128MB
Initializing USB.
Initialize First USB Controller
USB OHCI start : Power Switching Mode Changed from 2000902 to 2000b02
USB: Locating Class 09 Vendor 0000 Product 0000: USB Hub
Try to Initialize Second USB Controller
CFE initialized.
checking usb
ACK :
writing vfd
Starting splash screen.
Found splash image - Width = 720 Height = 576
x = 0, y= 0, bmpMemory=85000000, surfaceMemory=ac800000, splashPitch=1440, splas
hWidth=720, splashHeight=576
Loader:elf Filesys:raw Dev:flash0.kernel File: Options:mem=48M mem=256M@0x200000
00 rootfstype=jffs2 root=/dev/mtdblock0 rw
Loading: 0x80001000/6650112 0x80658900/129776 Entry address is 0x804d70f0
TP1 Entry Address at 0x80000ffc = 804d70f0
Starting program at 0x804d70f0
Linux version 3.9.6 (plnick@build-plnick) (gcc version 4.6.4 20120303 (prereleas
e) (GCC) ) #1 SMP Mon Mar 30 20:51:42 CEST 2015
Fetching vars from bootloader... found 11 vars.
Early serial console at MMIO32 0x10400b00 (options '115200n')
bootconsole [uart0] enabled
Options: sata=1 enet=1 emac_1=1 no_mdio=0 docsis=0 pci=1 smp=1 moca=0 usb=1
Using 512 MB + 0 MB RAM (from CFE)
bootconsole [early0] enabled
CPU revision is: 0002a044 (Brcm4380)
FPU revision is: 00130001
Determined physical RAM map:
memory: 10000000 @ 00000000 (usable)
memory: 10000000 @ 20000000 (usable)
bmem: adding 232 MB RESERVED region at 24 MB (0x0e800000@0x01800000)
Zone ranges:
Normal [mem 0x00000000-0x2fffffff]
Movable zone start for each node
Early memory node ranges
node 0: [mem 0x00000000-0x0fffffff]
node 0: [mem 0x20000000-0x2fffffff]
Primary instruction cache 32kB, VIPT, 2-way, linesize 64 bytes.
Primary data cache 64kB, 4-way, VIPT, cache aliases, linesize 64 bytes
PERCPU: Embedded 7 pages/cpu @81407000 s6400 r8192 d14080 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048
Kernel command line: bmem=232M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw ro
otflags=sync
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
__ex_table already sorted, skipping sort
Memory: 275508k/524288k available (4992k kernel code, 248780k reserved, 1261k da
ta, 268k init, 0k highmem)
Hierarchical RCU implementation.
NR_IRQS:128
Detected MIPS clock frequency: 405 MHz (202.500 MHz counter)
Calibrating delay loop... 403.45 BogoMIPS (lpj=201728)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
SMP: Booting CPU1...
SMP: CPU1 is running
Brought up 2 CPUs
devtmpfs: initialized
NET: Registered protocol family 16
USB0: power enable is active high; overcurrent is active low
PCI2.3->SDRAM window: 512 MB
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Linux video capture interface: v2.00
Advanced Linux Sound Architecture Driver Initialized.
PCI host bridge to bus 0000:00
pci_bus 0000:00: root bus resource [mem 0xd0000000-0xefffffff]
pci_bus 0000:00: root bus resource [io 0x0400-0x83ff]
pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
PCI host bridge to bus 0000:01
pci_bus 0000:01: root bus resource [mem 0x10510000-0x1051ffff]
pci_bus 0000:01: root bus resource [io 0x8400-0x87ff]
pci_bus 0000:01: No busn resource found for root bus, will use [bus 01-ff]
PCI: found device 14e4:8602 on SATA bus, slot 0 (irq 42)
pci 0000:01:00.0: BAR 5: assigned [mem 0x10510000-0x10510fff]
pci 0000:01:00.0: BAR 6: assigned [mem 0x10511000-0x105117ff pref]
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource upg
FS-Cache: Loaded
NET: Registered protocol family 2
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP: reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
msgmni has been set to 538
io scheduler noop registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x10400b00 (irq = 22) is a 16550A
console [ttyS0] enabled, bootconsole disabled
serial8250.0: ttyS1 at MMIO 0x10400b40 (irq = 66) is a 16550A
serial8250.0: ttyS2 at MMIO 0x10400b80 (irq = 67) is a 16550A
loop: module loaded
PCI: Enabling device 0000:01:00.0 (0000 -> 0003)
scsi0 : sata_brcmstb
scsi1 : sata_brcmstb
ata1: SATA max UDMA7 mmio m4096@0x10510000 port 0x10510000 irq 42
ata2: SATA max UDMA7 mmio m4096@0x10510000 port 0x10510100 irq 42
Broadcom STB NAND controller (BrcmNand Controller)
bcmemac: Broadcom STB 10/100 EMAC driver v3.0
bcmemac: registered interface #0 at 0x10080000 as 'eth0' (00:1d:ec:03:cc:71)
bcmemac: not registering interface #1 at 0x10090000 (no PHY detected)
usbcore: registered new interface driver zd1201
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-brcm ehci-brcm.0: Broadcom STB EHCI
ehci-brcm ehci-brcm.0: new USB bus registered, assigned bus number 1
ehci-brcm ehci-brcm.0: irq 62, io mem 0x10480300
ehci-brcm ehci-brcm.0: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ehci-brcm ehci-brcm.1: Broadcom STB EHCI
ehci-brcm ehci-brcm.1: new USB bus registered, assigned bus number 2
ehci-brcm ehci-brcm.1: irq 57, io mem 0x10480500
ehci-brcm ehci-brcm.1: USB 0.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-brcm ohci-brcm.0: Broadcom STB OHCI
ohci-brcm ohci-brcm.0: new USB bus registered, assigned bus number 3
ohci-brcm ohci-brcm.0: irq 63, io mem 0x10480400
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
ohci-brcm ohci-brcm.1: Broadcom STB OHCI
ohci-brcm ohci-brcm.1: new USB bus registered, assigned bus number 4
ohci-brcm ohci-brcm.1: irq 64, io mem 0x10480600
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
TCP: cubic registered
ata1: SATA link down (SStatus 4 SControl 300)
Key type dns_resolver registered
EBI CS0: setting up NAND flash (primary)
mtd->oobsize=0, mtd->eccOobSize=0
NAND_CS_NAND_XOR=00000001
B4: NandSelect=40000101, nandConfig=15142200, chipSelect=0
brcmnand_read_id: CS0: dev_id=ecf10095
After: NandSelect=40000101, nandConfig=15142200
Block size=00020000, erase shift=17
NAND Config: Reg=15142200, chipSize=128 MB, blockSize=128K, erase_shift=11
busWidth=1, pageSize=2048B, page_shift=11, page_mask=000007ff
BrcmNAND mfg ec f1 Samsung K9F1G08U0A 128MB on CS0
Found NAND on CS0: ACC=f7ff1010, cfg=15142200, flashId=ecf10095, tim1=4232222d,
tim2=00000d94
BrcmNAND version = 0x0302 128MB @00000000
Found NAND flash on Chip Select 0, chipSize=128MB, usable size=128MB, base=0
brcmnand_scan: B4 nand_select = 40000101
brcmnand_scan: After nand_select = 40000101
page_shift=11, bbt_erase_shift=17, chip_shift=27, phys_erase_shift=17
Brcm NAND controller version = 3.2 NAND flash size 128MB @18000000
ECC layout=brcmnand_oob_bch4_4k
brcmnand_scan: mtd->oobsize=64
brcmnand_scan: oobavail=50, eccsize=512, writesize=2048
brcmnand_scan, eccsize=512, writesize=2048, eccsteps=4, ecclevel=15, eccbytes=3
-->brcmnand_default_bbt
brcmnand_default_bbt: bbt_td = bbt_main_descr
Creating 8 MTD partitions on "brcmnand.0":
0x000000000000-0x000007200000 : "rootfs"
0x000007200000-0x000007600000 : "kernel"
0x000007600000-0x000007a00000 : "boot"
0x000007a00000-0x000007c00000 : "splash"
0x000007c00000-0x000007d00000 : "cfe"
0x000007d00000-0x000007d80000 : "mac"
0x000007d80000-0x000007e00000 : "env"
0x000007e00000-0x000007f00000 : "nvm"
PM: CP0 COUNT/COMPARE frequency depends on divisor
UBI: attaching mtd0 to ubi0
ata2: SATA link down (SStatus 4 SControl 300)
UBI: scanning is finished
UBI: attached mtd0 (name "rootfs", size 114 MiB) to ubi0
UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
UBI: good PEBs: 908, bad PEBs: 4, corrupted PEBs: 0
UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
UBI: max/mean erase counter: 100/5, WL threshold: 4096, image sequence number: 1
98218754
UBI: available PEBs: 0, total reserved PEBs: 908, PEBs reserved for bad PEB hand
ling: 16
ALSA device list:
UBI: background thread "ubi_bgt0d" started, PID 47
No soundcards found.
UBIFS: parse sync
UBIFS: background thread "ubifs_bgt0_0" started, PID 48
UBIFS: recovery needed
UBI: fixable bit-flip detected at PEB 514
UBI: schedule PEB 514 for scrubbing
UBIFS error (pid 1): ubifs_scan: corrupt empty space at LEB 743:126133
UBIFS error (pid 1): ubifs_scanned_corruption: corruption at LEB 743:126133
UBIFS error (pid 1): ubifs_scanned_corruption: first 843 bytes from LEB 743:1261
33
UBIFS error (pid 1): ubifs_scan: LEB 743 scanning failed
UBIFS: background thread "ubifs_bgt0_0" stops
VFS: Cannot open root device "ubi0:rootfs" or unknown-block(8,1): error -135
Please append a correct "root=" boot option; here are the available partitions:
1f00 116736 mtdblock0 (driver?)
1f01 4096 mtdblock1 (driver?)
1f02 4096 mtdblock2 (driver?)
1f03 2048 mtdblock3 (driver?)
1f04 1024 mtdblock4 (driver?)
1f05 512 mtdblock5 (driver?)
1f06 512 mtdblock6 (driver?)
1f07 1024 mtdblock7 (driver?)
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(8,1)
Rebooting in 180 seconds..
Please help me to solve this problem
BCM74130011
012
K1
K2
K3
K4
K5
Shmoo Version=3.8
DDR Freq=0x0000018C
%00000001%
RC1=00000004
WC1=FFFFFFF2
RC2=00000018
WC2=0000003A
RC3=0000000E
WC3=FFFFFFF2
RC4=0000000E
WC4=0000003E
NWC=00000018
RC5=00000004
WC5=00000018
RC6=00000018
WC6=00000018
NRC=0000000E
RW=00000015
WW=0000004D
BL=00000000
RC1=00000001
RC2=00000013
BL=00000001
RC1=00000002
RC2=00000012
BL=00000002
RC1=00000002
RC2=00000015
BL=00000003
RC1=00000003
RC2=00000012
BL=00000004
RC1=00000004
RC2=00000017
BL=00000005
RC1=00000005
RC2=00000018
BL=00000006
RC1=00000001
RC2=00000014
BL=00000007
RC1=00000003
RC2=00000015
3
COPY CODE
A567
writing vfd
DDR Freq: 396MHz
CPU speed: 405MHz
Device Tech: 1Gb
Total memory: 512MB
Boot Device: NAND
Total flash: 128MB
Initializing USB.
CFE initialized.
checking usb
ACK :
writing vfd
Zone ranges:
otflags=sync
NR_IRQS:128
Brought up 2 CPUs
FS-Cache: Loaded
loop: module loaded
tim2=00000d94
98218754
ling: 16
ALSA device list:
UBIFS: parse sync
33
Seems flash corrupted.
Thanks for response
Suddenly the box worked again without any reason
really i tried over and over, but it worked again normally
Thanks again for your response
