vu+uno tuner problem
mamdouhn
Hi,
I'm hoping someone can help me.
I have a vu+uno with dual tuner dvbs2
my problem is that there are no signal at all and i tried my cabel with another receiver and it is work fine
so i changed the dual tuner dvbs2 with the Single Tuner DVBS2 what came with the vu+uno
but now the uno doesn't regonized the tuner and give me dummy tuner not supported
i flashd fpg and i tried too many driver and too many images and nothing change .
to be more clear the dual tuner dvbs2 work for two years normal after that i start to have low signal with lnb A after with B then i stop to have signal from the tuner .
I do really need help, I don't know if is it a hardware problem or something with software!
Sent from my HTC 10 using Tapatalk
The VU+ Uno is quite an old receiver, but should still work.
Check your receiver for any signs of blown/damaged capacitors, and check the motherboard for signs of burning, or damage.
You could try the receiver on a different dish/LNB, to see if it works.
It might not be worth getting it repaired, or even trying a new tuner, given as it is so old, unless you can do it yourself.
Can be useful the output of
dmesg
command
root@vuuno:~# dmesg
[AUD]: AUDIO_SET_MIXER : amixl 0, amixr 0
[AUD]: AUDIO_SET_MIXER : next left volume 0, right volume 0
[AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
[AUD]: AUDIO_SET_MIXER -844808736
[AUD]: AUDIO_SET_MIXER : amixl 54, amixr 54
[AUD]: AUDIO_SET_MIXER : next left volume -3927, right volume -3927
[AUD]: AUDIO_SET_MUTE 1
bcm7413: hotplug_callback():
Hotplug - status.connected 0
EXT2-fs (sda1): error: ext2_lookup: deleted inode referenced: 1056769
EXT2-fs (sda1): error: ext2_lookup: deleted inode referenced: 40963
EXT2-fs (sda1): error: ext2_lookup: deleted inode referenced: 40965
EXT2-fs (sda1): error: ext2_lookup: deleted inode referenced: 40967
EXT2-fs (sda1): error: ext2_lookup: deleted inode referenced: 532484
EXT2-fs (sda1): error: ext2_lookup: deleted inode referenced: 532482
EXT2-fs (sda1): error: ext2_lookup: deleted inode referenced: 7757825
EXT2-fs (sda1): error: ext2_lookup: deleted inode referenced: 22
EXT2-fs (sda1): error: ext2_lookup: deleted inode referenced: 532483
EXT2-fs (sda1): error: ext2_lookup: deleted inode referenced: 532490
EXT2-fs (sda1): error: ext2_lookup: deleted inode referenced: 532496
EXT2-fs (sda1): error: ext2_lookup: deleted inode referenced: 532497
EXT2-fs (sda1): error: ext2_lookup: deleted inode referenced: 532501
EXT2-fs (sda1): error: ext2_lookup: deleted inode referenced: 532506
EXT2-fs (sda1): error: ext2_lookup: deleted inode referenced: 532507
EXT2-fs (sda1): error: ext2_lookup: deleted inode referenced: 253984
EXT2-fs (sda1): error: ext2_lookup: deleted inode referenced: 253987
EXT2-fs (sda1): error: ext2_lookup: deleted inode referenced: 253988
[AUD]: AUDIO_SET_MUTE 0
Hotplug - status.connected 1
Hotplug - connecting HDMI to display 0xf
[VID]: VIDEO_GET_SIZE src w: 1920 h:1080 display w:1920 h:1080
[VID]: VIDEO_GET_SIZE aspect: 1 1
[VID]: VIDEO_SELECT_SOURCE 1
[VID]: VIDEO_FREEZE 1 0
[AUD]: AUDIO_SELECT_SOURCE 1
[AUD]: AUDIO_PLAY 1 decoder start : 0
[AUD]: AUDIO_PLAY : Starting Playpump
[AUD]: AUDIO_PAUSE 1
[VID]: VIDEO_SET_STREAMTYPE 1
[VID]: VIDEO_PLAY 1 5 2
[VID]: VIDEO_SLOWMOTION 0 1
[AUD]: AUDIO_SET_BYPASS_MODE 11
[VID]: VIDEO_FAST_FORWARD 0 1
[AUD]: AUDIO_SET_BYPASS_MODE Stopping decoder
[AUD]: AAC downmix 0 state : 0
[AUD]: AUDIO_SET_BYPASS_MODE ReStart decoder
[AUD]: AUDIO_CONTINUE 1 2 aph=0x0
[VID]: VIDEO_CONTINUE 1 1
[VID]: VIDEO_FREEZE 1 1
[VID]: VIDEO_STOP 1 2
[VID]: VIDEO_SLOWMOTION 0 0
[VID]: VIDEO_FAST_FORWARD 0 0
[VID]: VIDEO_SELECT_SOURCE 0
[AUD]: AUDIO_STOP 1
[AUD]: AUDIO_SELECT_SOURCE 0
[VID]: VIDEO_GET_SIZE src w: 720 h:544 display w:720 h:544
[VID]: VIDEO_GET_SIZE aspect: 1 6
[AUD]: POLLIN
[AUD]: AUDIO_STOP 1
[AUD]: AUDIO_STOP 1
[AUD]: POLLIN
[AUD]: AUDIO_STOP 1
[VID]: VIDEO_GET_SIZE src w: 640 h:360 display w:640 h:360
[AUD]: POLLIN
[AUD]: AUDIO_STOP 1
[AUD]: POLLIN
[AUD]: AUDIO_STOP 1
[VID]: VIDEO_CLEAR_BUFFER 1 1 0
[AUD]: AUDIO_CLEAR_BUFFER 1 0
[AUD]: POLLIN
[AUD]: AUDIO_STOP 1
[AUD]: POLLIN
[AUD]: AUDIO_STOP 1
[AUD]: AUDIO_STOP 1
root@vuuno:~#
what i can not understnd why the receiver regonize the dual tuner dvbs2 but doesn't give any signal and when i plug the Single Tuner dvbs2 the receiver doesn't regonized the tuner and give me dummy tuner is not supported
Please, reboot your box and after it end boots, launch the dmesg command again.
root@vuuno:~# dmesg
pci 0000:01:00.0: [14e4:8602] type 00 class 0x01010f
PCI: found device 14e4:8602 on SATA bus, slot 0 (irq 42)
pci 0000:01:00.0: reg 24: [mem 0x00000000-0x00000fff]
pci 0000:01:00.0: reg 30: [mem 0x00000000-0x000007ff pref]
pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
pci 0000:01:00.0: BAR 5: assigned [mem 0x10510000-0x10510fff]
pci 0000:01:00.0: BAR 6: assigned [mem 0x10511000-0x105117ff pref]
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource upg
FS-Cache: Loaded
NET: Registered protocol family 2
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP: reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
NET: Registered protocol family 1
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
PCI: CLS 0 bytes, default 64
Registering unionfs 2.5.13 (for 3.9.11)
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
msgmni has been set to 537
io scheduler noop registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x10400b00 (irq = 22) is a 16550A
console [ttyS0] enabled, bootconsole disabled
serial8250.0: ttyS1 at MMIO 0x10400b40 (irq = 66) is a 16550A
serial8250.0: ttyS2 at MMIO 0x10400b80 (irq = 67) is a 16550A
loop: module loaded
sata_brcmstb 0000:01:00.0: version 4.0
__clk_enable: sata [1]
PCI: Enabling device 0000:01:00.0 (0000 -> 0003)
sata_brcmstb 0000:01:00.0: setting latency timer to 64
scsi0 : sata_brcmstb
scsi1 : sata_brcmstb
ata1: SATA max UDMA7 mmio m4096@0x10510000 port 0x10510000 irq 42
ata2: SATA max UDMA7 mmio m4096@0x10510000 port 0x10510100 irq 42
Broadcom STB NAND controller (BrcmNand Controller)
bcmemac: Broadcom STB 10/100 EMAC driver v3.0
bcmemac: registered interface #0 at 0x10080000 as 'eth0' (00:1d:ec:03:1f:ee)
bcmemac: not registering interface #1 at 0x10090000 (no PHY detected)
usbcore: registered new interface driver zd1201
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
__clk_enable: usb [1]
ehci-brcm ehci-brcm.0: Broadcom STB EHCI
ehci-brcm ehci-brcm.0: new USB bus registered, assigned bus number 1
ehci-brcm ehci-brcm.0: irq 62, io mem 0x10480300
ehci-brcm ehci-brcm.0: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ehci-brcm ehci-brcm.1: Broadcom STB EHCI
ehci-brcm ehci-brcm.1: new USB bus registered, assigned bus number 2
ehci-brcm ehci-brcm.1: irq 57, io mem 0x10480500
ehci-brcm ehci-brcm.1: USB 0.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-brcm ohci-brcm.0: Broadcom STB OHCI
ohci-brcm ohci-brcm.0: new USB bus registered, assigned bus number 3
ohci-brcm ohci-brcm.0: irq 63, io mem 0x10480400
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
ohci-brcm ohci-brcm.1: Broadcom STB OHCI
ohci-brcm ohci-brcm.1: new USB bus registered, assigned bus number 4
ohci-brcm ohci-brcm.1: irq 64, io mem 0x10480600
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
Success! Registering the characther device success with 0
blackhole initialised
hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
TCP: cubic registered
Key type dns_resolver registered
EBI CS0: setting up NAND flash (primary)
mtd->oobsize=0, mtd->eccOobSize=0
NAND_CS_NAND_XOR=00000001
B4: NandSelect=40000101, nandConfig=15142200, chipSelect=0
brcmnand_read_id: CS0: dev_id=ecf10095
After: NandSelect=40000101, nandConfig=15142200
Block size=00020000, erase shift=17
NAND Config: Reg=15142200, chipSize=128 MB, blockSize=128K, erase_shift=11
busWidth=1, pageSize=2048B, page_shift=11, page_mask=000007ff
BrcmNAND mfg ec f1 Samsung K9F1G08U0A 128MB on CS0
Found NAND on CS0: ACC=f7ff1010, cfg=15142200, flashId=ecf10095, tim1=4232222d, tim2=00000d94
usb 1-2: new high-speed USB device number 2 using ehci-brcm
BrcmNAND version = 0x0302 128MB @00000000
ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Found NAND flash on Chip Select 0, chipSize=128MB, usable size=128MB, base=0
brcmnand_scan: B4 nand_select = 40000101
brcmnand_scan: After nand_select = 40000101
page_shift=11, bbt_erase_shift=17, chip_shift=27, phys_erase_shift=17
Brcm NAND controller version = 3.2 NAND flash size 128MB @18000000
ECC layout=brcmnand_oob_bch4_4k
brcmnand_scan: mtd->oobsize=64
brcmnand_scan: oobavail=50, eccsize=512, writesize=2048
brcmnand_scan, eccsize=512, writesize=2048, eccsteps=4, ecclevel=15, eccbytes=3
-->brcmnand_default_bbt
brcmnand_default_bbt: bbt_td = bbt_main_descr
Bad block table Bbt0 found at page 0000ffc0, version 0x01 for chip on CS0
Bad block table 1tbB found at page 0000ff80, version 0x01 for chip on CS0
nand_read_bbt: Bad block at 0x05000000
Creating 8 MTD partitions on "brcmnand.0":
0x000000000000-0x000007200000 : "rootfs"
0x000007200000-0x000007600000 : "kernel"
0x000007600000-0x000007a00000 : "boot"
0x000007a00000-0x000007c00000 : "splash"
0x000007c00000-0x000007d00000 : "cfe"
0x000007d00000-0x000007d80000 : "mac"
0x000007d80000-0x000007e00000 : "env"
0x000007e00000-0x000007f00000 : "nvm"
PM: CP0 COUNT/COMPARE frequency depends on divisor
UBI: attaching mtd0 to ubi0
ata1.00: ATA-7: TOSHIBA MK1637GSX, DL050J, max UDMA/100
ata1.00: 312581808 sectors, multi 16: LBA48 NCQ (depth 0/32)
ata1.00: configured for UDMA/100
scsi 0:0:0:0: Direct-Access ATA TOSHIBA MK1637GS DL05 PQ: 0 ANSI: 5
sd 0:0:0:0: [sda] 312581808 512-byte logical blocks: (160 GB/149 GiB)
sd 0:0:0:0: Attached scsi generic sg0 type 0
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sda: sda1
sd 0:0:0:0: [sda] Attached SCSI disk
ata2: SATA link down (SStatus 4 SControl 300)
UBI: scanning is finished
UBI: attached mtd0 (name "rootfs", size 114 MiB) to ubi0
UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
UBI: good PEBs: 911, bad PEBs: 1, corrupted PEBs: 0
UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
UBI: max/mean erase counter: 11/2, WL threshold: 4096, image sequence number: 2069139693
UBI: available PEBs: 0, total reserved PEBs: 911, PEBs reserved for bad PEB handling: 19
ALSA device list:
No soundcards found.
UBI: background thread "ubi_bgt0d" started, PID 50
UBIFS: parse sync
UBIFS: background thread "ubifs_bgt0_0" started, PID 51
UBIFS: mounted UBI device 0, volume 0, name "rootfs"(null)
UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
UBIFS: FS size: 111357952 bytes (106 MiB, 877 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
UBIFS: reserved for root: 0 bytes (0 KiB)
UBIFS: media format: w4/r0 (latest is w4/r0), UUID F61E63C4-CB9B-432C-8488-81EAE960A578, small LPT model
VFS: Mounted root (ubifs filesystem) on device 0:11.
devtmpfs: mounted
Freeing unused kernel memory: 260k freed
NET: Registered protocol family 10
procmk_init
dvb_bcm7413: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
DVB: registering new adapter (vuuno)
enable MII = 0
Hotplug - connecting HDMI to display 0xe
[GPIO]Default
[GPIO]RST Default
[GPIO]fpga secu
[GP]:brcm_pwm_init
brcm_demux_init: $Id: bcm7335_demux.c,v 0.6 $
[VID]: 6bcm7335_video_init
[AUD]: 6bcm7335_audio_init
bcm7413: bcm7335_frontend_init(): vtuner1 : 1
[MPVR]: >> misc_pvr_init
input: dreambox advanced remote control (native) as /devices/virtual/input/input0
[LCD]: registered
[CI]:0 1
[CI]: registered ci0 0
[CI]: registered ci1 0
[DFP]: registered dbox fp
[DFP]: Scart 9597 is found 4
[SC]: registered sci0
[SC]: registered sci1
system_time_set wakeup mode get
system_time_set wakeup mode get 0xc4
fpga update driver loaded
udevd (114): /proc/114/oom_adj is deprecated, please use /proc/114/oom_score_adj instead.
usbcore: registered new interface driver rtl8192cu
EXT2-fs (sda1): warning: mounting unchecked fs, running e2fsck is recommended
IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Adding 262140k swap on /hdd/swapfile. Priority:-1 extents:67 across:270612k
[VID]: VIDEO_SET_STREAMTYPE 0
[VID]: VIDEO_PLAY 1 2 0
IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[VID]: VIDEO_STOP 0 1
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
svc: failed to register lockdv1 RPC service (errno 124).
[LCD]: unknown cmd 0x1015
[CI]:ci_dev_open
[CI]:entering.. A NEXUS_DvbCi_Open
[CI]:NEXUS_DvbCi_Open done..
[CI]:Installing callbacks
[CI]:Forcing card check
[CI]:Card insertion status changed
[CI]:entering.. B NEXUS_DvbCi_Open
[CI]:Card B insertion status changed
[CI]: CI interface initialised
[CI]:ci1_dev_open
[AUD]: AUDIO_SET_MIXER -845046304
root@vuuno:~#
root@vuuno:~# dmesg
FS-Cache: Loaded
loop: module loaded
sda: sda1
ALSA device list:
UBIFS: parse sync
devtmpfs: mounted
procmk_init
enable MII = 0
[GPIO]Default
[GPIO]RST Default
[GPIO]fpga secu
[GP]:brcm_pwm_init
[LCD]: registered
[CI]:0 1
[CI]:ci_dev_open
[CI]:ci1_dev_open
root@vuuno:~#
Seems is all OK.
Can you post the output of the following command?
 cat /proc/bus/nim_sockets
