VU+ Uno4K SE - No signal on Vertical
WebMan
Hello...
Has anyone else encountered this problem?
It has no signal on V channels on SAT, the receiver is almost 2 years old (February 2018), but it is only used for ... watching football matches :)
Tips?
Warranty (Hm-sat)?
Thanks...
#Alex: no, the lists are manually made, tailored for me :D ...
I found the trouble, if I tell you, you can't believe it: A FUCKED MORON has linked my cable with a T, I think he liked my toroidal more than the common one ...
UNBELIEVABLE !!!!
