vu+ usb turbo tuner
Is it new ? Was it working before ?
Try to disconnect all you usb devices and attach only the turbo tuner.
It's 2 years old and suddenly stop working.
Only red led light no matter what i try to do and of course it's not show up in tuner configuration
Also tried with OBH in OMB and same issue
Red led light? Should be green led light....
Changed to another USB port?
In OBH you need to download the driver, did you?
I went to see here in mine, the red led light means that there is no signal on the coaxial cable (I turned off the tuner coaxial cable).
Curious is that I have my configured for DVB-T, which is what I have, I turned off this setting and activated the DVB-C and continues to receive the channels that are, all, DVB-T...
