VU+ Zero 4K : blindscan Problem
ahmedmoselhi
ok i have got this issue on all images (not just openvision image) .. the problem is when i try to do blind scan all transponders bellow 11700mhz seems well-detected compared to normal satellites.xml file
but all transponders above 11700 mhz are all wrong!!!
for example sat. 16.0 E :
blindscan results :
<?xml version="1.0" encoding="iso-8859-1"?>
    File created on Tuesday, 06 of October 2020, 01:17:42
    using vuzero4k receiver running Enigma2 image, version 9.0,
    build 0, with the blindscan plugin
    Search parameters:
        Tuner A: Vuplus DVB-S NIM(SI2166) (DVB-S2X)
        Satellite: 16.0E Ku-band Eutelsat 16A
        Start frequency: 10700MHz
        Stop frequency: 12750MHz
        Polarization: vertical and horizontal
        Lower symbol rate: 1000
        Upper symbol rate: 45000
        Only save unknown tranponders: no
        Filter out adjacent satellites: no
        Scan duration: 172 seconds
<satellites>
    <sat name="16.0E Ku-band Eutelsat 16A" flags="0" position="160">
        <transponder frequency="10719998" symbol_rate="30000000" polarization="0" fec_inner="0" system="0" modulation="1" />
        <transponder frequency="10761548" symbol_rate="30000000" polarization="0" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="10803032" symbol_rate="29950000" polarization="0" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="10844516" symbol_rate="30000000" polarization="0" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="10886001" symbol_rate="30000000" polarization="0" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="10927485" symbol_rate="30000000" polarization="0" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="10971722" symbol_rate="27500000" polarization="1" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="11010191" symbol_rate="27500000" polarization="1" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="11054821" symbol_rate="27500000" polarization="1" fec_inner="8" system="1" modulation="1" />
        <transponder frequency="11088310" symbol_rate="5000000" polarization="0" fec_inner="4" system="1" modulation="2" />
        <transponder frequency="11093815" symbol_rate="27500000" polarization="1" fec_inner="8" system="1" modulation="1" />
        <transponder frequency="11094274" symbol_rate="5000000" polarization="0" fec_inner="4" system="1" modulation="2" />
        <transponder frequency="11130253" symbol_rate="16593000" polarization="1" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="11150242" symbol_rate="14375000" polarization="1" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="11157254" symbol_rate="45000000" polarization="0" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="11176849" symbol_rate="30000000" polarization="1" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="11220038" symbol_rate="30000000" polarization="0" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="11230261" symbol_rate="42000000" polarization="1" fec_inner="8" system="1" modulation="1" />
        <transponder frequency="11261522" symbol_rate="30000000" polarization="0" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="11282297" symbol_rate="30000000" polarization="1" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="11319718" symbol_rate="30000000" polarization="1" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="11363955" symbol_rate="30000000" polarization="1" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="11386040" symbol_rate="30000000" polarization="0" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="11424838" symbol_rate="27500000" polarization="1" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="11470057" symbol_rate="30000000" polarization="1" fec_inner="4" system="1" modulation="2" />
        <transponder frequency="11470057" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="11511542" symbol_rate="29951000" polarization="1" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="11511542" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="11550732" symbol_rate="30000000" polarization="1" fec_inner="4" system="1" modulation="2" />
        <transponder frequency="11553026" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="11594510" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="11594576" symbol_rate="30000000" polarization="1" fec_inner="4" system="1" modulation="2" />
        <transponder frequency="11636060" symbol_rate="30000000" polarization="1" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="11636060" symbol_rate="30000000" polarization="0" fec_inner="4" system="1" modulation="2" />
        <transponder frequency="11677544" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="11736001" symbol_rate="30000000" polarization="0" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="11777550" symbol_rate="30000000" polarization="0" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="11821722" symbol_rate="27500000" polarization="1" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="11860191" symbol_rate="27500000" polarization="1" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="11904756" symbol_rate="27500000" polarization="1" fec_inner="8" system="1" modulation="1" />
        <transponder frequency="11938310" symbol_rate="5000000" polarization="0" fec_inner="4" system="1" modulation="2" />
        <transponder frequency="11943815" symbol_rate="27500000" polarization="1" fec_inner="8" system="1" modulation="1" />
        <transponder frequency="11944274" symbol_rate="5000000" polarization="0" fec_inner="4" system="1" modulation="2" />
        <transponder frequency="11980253" symbol_rate="16593000" polarization="1" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="12000242" symbol_rate="14375000" polarization="1" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="12007254" symbol_rate="45000000" polarization="0" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="12026849" symbol_rate="30000000" polarization="1" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="12070038" symbol_rate="30000000" polarization="0" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="12080261" symbol_rate="42000000" polarization="1" fec_inner="8" system="1" modulation="1" />
        <transponder frequency="12111522" symbol_rate="30000000" polarization="0" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="12132297" symbol_rate="30000000" polarization="1" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="12169980" symbol_rate="30000000" polarization="1" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="12213889" symbol_rate="30000000" polarization="1" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="12236040" symbol_rate="30000000" polarization="0" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="12272806" symbol_rate="27500000" polarization="1" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="12320057" symbol_rate="30000000" polarization="1" fec_inner="4" system="1" modulation="2" />
        <transponder frequency="12320057" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="12361542" symbol_rate="29950000" polarization="1" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="12361542" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="12400601" symbol_rate="30000000" polarization="1" fec_inner="4" system="1" modulation="2" />
        <transponder frequency="12403026" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="12444510" symbol_rate="30000000" polarization="1" fec_inner="4" system="1" modulation="2" />
        <transponder frequency="12444510" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="12486060" symbol_rate="30000000" polarization="1" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="12486060" symbol_rate="30000000" polarization="0" fec_inner="4" system="1" modulation="2" />
        <transponder frequency="12527544" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="2" />
    </sat>
</satellites>
normal satellites.xml file (from oe-allience git) :
    <sat name="16.0E Ku-band Eutelsat 16A" flags="1" position="160">
        <transponder frequency="10721000" symbol_rate="30000000" polarization="0" fec_inner="3" system="0" modulation="1" />
        <transponder frequency="10762000" symbol_rate="30000000" polarization="0" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="10804000" symbol_rate="29950000" polarization="0" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="10804000" symbol_rate="30000000" polarization="0" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="10845000" symbol_rate="30000000" polarization="0" fec_inner="6" system="1" modulation="1" />
        <transponder frequency="10845000" symbol_rate="30000000" polarization="0" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="10887000" symbol_rate="30000000" polarization="0" fec_inner="6" system="1" modulation="1" />
        <transponder frequency="10887000" symbol_rate="30000000" polarization="0" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="10928000" symbol_rate="30000000" polarization="0" fec_inner="6" system="1" modulation="1" />
        <transponder frequency="10928000" symbol_rate="30000000" polarization="0" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="10972000" symbol_rate="27500000" polarization="1" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="11011000" symbol_rate="27500000" polarization="1" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="11016000" symbol_rate="2083000" polarization="0" fec_inner="8" system="1" modulation="2" />
        <transponder frequency="11024000" symbol_rate="3333000" polarization="0" fec_inner="4" system="0" modulation="1" />
        <transponder frequency="11055000" symbol_rate="27500000" polarization="1" fec_inner="8" system="1" modulation="1" />
        <transponder frequency="11069000" symbol_rate="355000" polarization="0" fec_inner="2" system="0" modulation="1" />
        <transponder frequency="11069000" symbol_rate="375000" polarization="0" fec_inner="7" system="1" modulation="1" />
        <transponder frequency="11070000" symbol_rate="176000" polarization="0" fec_inner="3" system="0" modulation="1" />
        <transponder frequency="11070000" symbol_rate="274000" polarization="0" fec_inner="1" system="0" modulation="1" />
        <transponder frequency="11094000" symbol_rate="27500000" polarization="1" fec_inner="8" system="1" modulation="1" />
        <transponder frequency="11131000" symbol_rate="16593000" polarization="1" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="11151000" symbol_rate="14375000" polarization="1" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="11158000" symbol_rate="45000000" polarization="0" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="11178000" symbol_rate="30000000" polarization="1" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="11221000" symbol_rate="30000000" polarization="0" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="11231000" symbol_rate="42000000" polarization="1" fec_inner="8" system="1" modulation="1" />
        <transponder frequency="11262000" symbol_rate="30000000" polarization="0" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="11283000" symbol_rate="30000000" polarization="1" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="11324000" symbol_rate="30000000" polarization="1" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="11356000" symbol_rate="45000000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="11366000" symbol_rate="30000000" polarization="1" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="11387000" symbol_rate="30000000" polarization="0" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="11427000" symbol_rate="27500000" polarization="1" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="11471000" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="11471000" symbol_rate="30000000" polarization="0" fec_inner="6" system="1" modulation="1" />
        <transponder frequency="11471000" symbol_rate="30000000" polarization="1" fec_inner="4" system="1" modulation="2" />
        <transponder frequency="11512000" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="11512000" symbol_rate="30000000" polarization="0" fec_inner="6" system="1" modulation="1" />
        <transponder frequency="11512000" symbol_rate="29950000" polarization="1" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="11554000" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="11554000" symbol_rate="30000000" polarization="0" fec_inner="4" system="1" modulation="1" />
        <transponder frequency="11554000" symbol_rate="30000000" polarization="1" fec_inner="4" system="1" modulation="2" />
        <transponder frequency="11595000" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="11595000" symbol_rate="30000000" polarization="1" fec_inner="4" system="1" modulation="2" />
        <transponder frequency="11596000" symbol_rate="29980000" polarization="0" fec_inner="6" system="1" modulation="1" />
        <transponder frequency="11637000" symbol_rate="30000000" polarization="0" fec_inner="4" system="1" modulation="2" />
        <transponder frequency="11637000" symbol_rate="30000000" polarization="0" fec_inner="6" system="1" modulation="1" />
        <transponder frequency="11637000" symbol_rate="30000000" polarization="1" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="11678000" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="11678000" symbol_rate="30000000" polarization="0" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="12541000" symbol_rate="19970000" polarization="1" fec_inner="3" system="1" modulation="1" />
        <transponder frequency="12562000" symbol_rate="30000000" polarization="0" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="12564000" symbol_rate="3617000" polarization="1" fec_inner="3" system="0" modulation="1" />
        <transponder frequency="12570000" symbol_rate="3703000" polarization="0" fec_inner="5" system="0" modulation="1" />
        <transponder frequency="12593000" symbol_rate="2500000" polarization="1" fec_inner="2" system="0" modulation="1" />
        <transponder frequency="12604000" symbol_rate="29980000" polarization="0" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="12606000" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="1" />
        <transponder frequency="12639000" symbol_rate="10833000" polarization="0" fec_inner="7" system="1" modulation="2" />
        <transponder frequency="12643000" symbol_rate="27500000" polarization="1" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="12654000" symbol_rate="11111000" polarization="0" fec_inner="2" system="0" modulation="1" />
        <transponder frequency="12660000" symbol_rate="2222000" polarization="0" fec_inner="4" system="1" modulation="2" />
        <transponder frequency="12676000" symbol_rate="2667000" polarization="0" fec_inner="3" system="1" modulation="1" />
        <transponder frequency="12687000" symbol_rate="29980000" polarization="0" fec_inner="3" system="1" modulation="1" />
        <transponder frequency="12694000" symbol_rate="2222000" polarization="0" fec_inner="4" system="1" modulation="1" />
        <transponder frequency="12699000" symbol_rate="9880000" polarization="0" fec_inner="2" system="0" modulation="1" />
        <transponder frequency="12717000" symbol_rate="7500000" polarization="0" fec_inner="3" system="1" modulation="1" />
        <transponder frequency="12739000" symbol_rate="2256000" polarization="0" fec_inner="3" system="0" modulation="1" />
    </sat>
this problem is described here : https://github.com/oe-alliance/oe-alliance-plugins/issues/384
