Johan Oviedo
Hi all,
My receiver Vu+ Zero 4K, stopped tunning channels from satellites connected to port different than port 1.
For example, the Diseqc have this ports connections:
Port1 : Sat1
Port2 : Sat2
Port3 : Sat3
Port4 : Sat4
Configuration Advanced:
Sat1: 58W C-Band, Diseqc 1.0, Port1
Sat1: 70W Universal LNB, Diseqc 1.0, Port2
Sat1: 61W Universal LNB, Diseqc 1.0, Port3
Sat1: 81W Universal LNB, Diseqc 1.0, Port4
Previous channels that I used to see from 70, 61 and 81, now are not having signal.
If a blind scan is done on any of these 3 satellitels, the channels from Sat1(58w in port1) are scanned.
Even though a sat is configured to port2, 3 or 4, its signal is received if the cable is connected to port1, and port1 only.
PS: Vertical and Horizontal transpronders of the Sat1 are tunned correctly.
Is this issues a HW issue? Could be the tunner be broken?
I already try using other diseqcs, and flashing other images
Same configurations works on other receivers that I have.
Providing debug logs, I'm using OpenBlackHole
regards,
Johan
Port1 : Sat1
Port2 : Sat2
Port3 : Sat3
Port4 : Sat4
regards,
Johan
