VU Zero 4K tuner driver PROBLEM?!
Neo64
Good evening,
the decoder works perfectly with your picture, but there is a big bug that I hope the master can fix. A signal that shows the decoder in both dimensions -% or decibels - is always 100%, even if the "user interface option" is changed. shows again 100%.
Thank you for your attention
Supposedly, soon Teamman, who makes Vu and decoder drivers, will be able to fix this annoying bug
Blind scans even if it works, the tuner displaying on all channels a 100% signal similar to Dream 500 than a renowned VU decoder. First, the level of the signal and then the other "tickles
