Vu+ zero Black hole 3.0.3 with TL-WN822N
Adrian0sevich13
Hello everyone,
This is the first time I try to install a wifi adapter in my box.
I have got a box (vu+ zero) with image ( black hole 3.0.3) and I want to install a wireless adapter TP-Link TL-WN822N, but I´m not sure if it´s compatible with Vu+ zero and black hole.
My box don´t recognize this device, I suppose that I´ll need to install the driver.
Do you know if there is a driver for this adapter that I can install in my vu+ zero?
Could you help me?
Thank you very much in advance
Regards,
Any tp link should work but never had much luck with wireless on blackhole on my duo2 so just used a different image and never had a problem.
