vu zero crash runs for 20 minutes and stops
scorpionoir009
welcome
I have two vu plus zero first run without any problem
And the second runs for 20 minutes and stops and does not respond to the remote control
But after the re-run again
Accompanying the image you to stop
log uploaded
i test all image crached
openatv-5.3-vuzero-20160703_usb
BlackHole-2.1.7-vuzero_usb_release_20150707_c6f93e5
openbh-0.6-vuzero-20160627_usb_release_dfa51a6
OpenPLi-4.0-beta-vuzero-20160703_usb
vti-image-vuzero-20160516235951_vti_9-0-3_usb (1)
and boot
vuplus_zero_cfe_v1.04
  • E2Log.txt
    E2Log.txt
welcome
log uploaded
and boot
It´s not allowed in this board, any discussion about any kind of illegal stuff.
The crashlog demonstrates clearly that you are using emulators, and this is against our board rules, regarding §4. of it.--> http://www.vuplus-community.net/rules.html
More: One file is the log, the other ??????
Ok I will re-updated images openbh-0.6-vuzero-20160627_usb_release_dfa51a6
Without the use of emu and send you log
Is it the best way possible for log
ihave this methode
init 4
enigma2 >/tmp/E2Log.txt 2>&1
ihave this methode
init 4
You can find the log in /home/root folder ... if you haven't change the file location for logs ... on log manager ( MENU>SETUP>SYSTEM>USER INTERFACE>LOGS )
Note: Don´t change the default skin, because it seems that you are using though, a different skin.
We don´t support other images, rather then BlackHole, OpenBlackHole or OpenBH ( 04 and 06 ).
i dont have log in /home/root
What Skin are you using? There is an asking for wait9.png file where the image it will ask only for wait8.png. I doubt you are using image default skin MX_HQ9W.
It seems you have Epg.dat and timeshift setted to flash memory that is causing the crash.
Note: Don´t use a backup image ... try re-flash your STB ( from scratch ) with another USB device formated as FAT32 FS.
In your log file timeshift is always active
but for timeshift is not enough diskspace .
Do you use timeshift and do you have harddisk/USB in use for timeshift ??
Or the remote button play/ timeshift is continuous active or defective ?
in my remote dont use time shift
I think the problem with the device
Because the seller gave me the serial number does not match
