My VU+ Zero got hanged
It was plugged in with Ethernet connection with following settings; Auto update of Openpli And my Samsung Smart TV was configured to be ‘ON’ and even switched off one I switch off through VU Zero and simultaneously VU Zero was handled through my Smart TV.
Everything was working fine and I switched off TV at night.
In morning I switched on VU Zero but nothing happened so I tried the TV remote, and TV gets On but VU Zero seems dead.
No display of any kind,
I tried every mean to reach VU Zero if I can get it On or can re-flash the image but failed from all directions.
Everything seems dead beside Ethernet Jack have both lights On VU Zero do not respond by any means..
Is there anyway if it can go to Factory Default and then I may reinstall the Blackhole or Openpli ..
