Conn Nargol
Hello,
I have a very strange problem as I cannot flash the VU+ Zero.
It seems that the flashing process goes smoothly and after a few minutes, the light blinks as normal.
But when I turn the Vu+ on, I only see the BlackHole Logo for a few second, then nothing... black screen.
If I try to install another image, the process also seems to work and on restart...BlackHole logo and black screen (Normally I should have seen the other image logo not the BH ???)
Is there a solution to completely reset the Vu+ ?
Thank you very much for your lights ;-)
Frank
Frank
