What is the model number of the TP Link? Have you tested it and made sure that it is connected to the internet?
As I understand, there are powerlines adapter, I'm right?My TP link TL is the PA4025Pkit, yes I tested with my apple tv is fontionne it very well, you do not know if I have to install in my black hole? I also tested the brand Devolo, same result.
you know where the problem may come?
Tanks
Yes i use TP LinkAs I understand, there are powerlines adapter, I'm right?
I don't see any kind of problems to use Powerlines.Yes i use TP Link
