Vu zero no sudden no signal
mleczus1
Hope to get help here. Lots of rain yestarday and no signal while i was at work. Today i tried to sort out. Signal was jumping crazy on SNR . Thought is dish cable or lnb. So i start on that. However when tried to re-fit cable on box I relized that even disconnected it does the same thing. Video in link. Did reset reboot and hard reset. No luck so put new blackhole image and its still same. Even with no sat cable connected to box. So is my box faulty ?
I don't think so ... which I didn't realize: did you replace the cable that comes from the LNB to the box with a new one?
If you have the possibility to try the installation with another box or take Zero to an installation that is ok, this will be a test.
Didnt try that yet. But how can I have this reading while cable is disconnected from box. I think it should be on 10-30 somewhere and not moving... or am i wrong
