Vu+ Zero reboots when zapping channels (or scanning)
Gonzalo Fernandez
Hi all!
I have a problem with my new Vu+ Zero box:
- Box starts without issues
- I can see the menus
- I can setup my satellite (58.0W -> Sky Mexico) in the tuner
The problem happens when I try to do anything involving the antenna, like scanning for channels, or zapping to any channel.
I've tried to do:
- updated the image to the latest (vuplus-image-vuzero-20150416164042_usb)
- updated the CFE (not sure if this worked, as the ZIP in vuplus.com gives me an error when uncompressing).
- updated the satellites.xml in the box (both /etc/tuxbox and /etc/enigma2)
- updated the box settings with the ones that I use for my Vu+ Duo with DreamboxEdit
I enabled the logs, I'm attaching the log when I try to scan the 58.0W satellite.
Maybe someone can take a look and see if I'm doing anything wrong, please?
Thanks!
