VU+ Zero - remote programming
cactusek
I need to program my remote control with vu + zero to control the volume of the TV set (TCL 50P615). I do this using the 1 + 3 method and typing in the code. I found in the VU Uno manual that the code for TCL is "2856" but it doesn't work. Does anyone know the code for this manufacturer? Autosearch did not find a code - I held the mute button for many minutes.
Do you have a solution? I have the same problem with my new TCL TV (C725).
