VU+ Zero rs232/ir
platinum2014
Hi,
Ive bought HDMI extenders with IR, but problem is that the connector is stereo 3,5mm minijack.
And the port on the VU+ Zero is IR/RS232. How come they are using this old variant still? Or is there another technial issue? Now to the main problem, how to find the right kind of adapter from ir/rs232 (quess its rj11) to stereo 3,5mm minijack? Ive tried to search alot for this, but havent had any luck besides some china sites likes aliexpress etc. Was hoping someone can point me to the right location or know exactly what needed for getting this to work? My plan is to have the receiver in a separate closet and using only HDMI extenders and Network cable (CAT6a) to transfer the HDMI signal, but right now the main problem is the IR extender functionality.
BR Anders
As far as I know IR Extender connector on Zero is only for remote and not for HDMI
You can extend HDMI only if you use HDMI port signals .
O sorry my mistake.
First you have to find pinout
But I think it's not complicated if I remember with three wire
Hi, Yes I reckon the pinout isnt that complicated. But was thinking there was some sort of adapter directly to convert from rs232/rj11.
Thanks for the reply!
