bidwisolutions
Good afternoon, I have a problem maybe someone can help me out. I have a VU+ zero and first installed a black hole image but had problems with IPTV streams. Then i decided to change the image to OpenPLI. I noticed that the box first shows the blackhole screen then changes to openpli and boots. Sometimes the internet is not available and for the IPTV streams to work i need to restart enigma. when i changed the image to open blackhole, it did the same. I tried to install Openpli image on a new Zero and works fine. Is there a way to flash the zero to its factory defaults so not to have the blackhole screen coming up first?
Thanks
Thanks
