Z
zypo
Guest
A few hours ago I got my Vu+ Zero and installed it. Works like a charm when used in the traditional way, i.e. with TV and remote. The web interface works too and I can read EPG, turn the device on and off etc.
But streaming from the web interface does not work. It gives me the m3u playlist file which I open with VLC. VLC seems to connect successfully to the box, and a red sphere also appears next to the power switch in the WebIF when VLC is "playing", and disappears when I press stop in VLC. But no video or audio appears.
The software is default (though I installed some "stream TV" from the menu at random). Software information given by the web interface is shown below. I tried to run firmware upgrade from the menus but it didn't find firmware.
Should I try some other software, e.g. OpenPLi? Or upgrade this software?
I'll be very happy if you can help me to get streaming to work by tomorrow.
Box
Brand: Vu+
Model: Zero
Chipset: 7362
Frontprocessor Version: 0
Total Memory: 315444 kB
Free Memory: 254060 kB
Box Uptime: 0:37
Software
System OE: OE 2.0
Distro: official
Firmware version: Experimental 2015-09-14.
Driver date: 3.13.5-r22-20150623
Kernel version: 3.13.5
Gui version: 2015-04-22-vuplus_experimental_factory
Tuners
Tuner A: BCM7362 DVB-S2 NIM (internal) (DVB-S2)
Network Interface: eth0
DCHP: True
IP address: censored but correct
Subnet mask: 255.255.255.0
Gateway: censored but correct
MAC address: censored but correct
IPv6 address(es): IPv4-only Python/Twisted
