Vu+ Zero streaming problems
tine_ulli
Hi,
I have now tried on my Zero the latest VTi and BH images but still encounter the same problem. My Zero receives a SAT signal and is connect by LAN to a WLAN router. Now I would like to receive via WLAN the live stream, to watch it with the Vu+ app on android or VLC on a PC.
What I observe is that it works typically for a couple of minutes, then the images freeze. When I zap to the next channel, it starts ok but eventually I see again the same problem.
Any hints on what is the problem and how to fix it?
Ok, after a lot of trying it seems I found the problem. It seems like some unpredicatable behavious of my router. Slowing down the data rate just a bit seems to be rather critical. I now bypassed the router with a direct link from the Vu Zero to a Powerlan. From there I can share the signal with other devices and it works fine.
