Hi all,
I recently purchased a Vu+ Zero box to test my new satellite setup.
I currently have a single dish with 3x quattro LNBs, feeding into a EMP 12/8 multi-switch. The dish is aligned to 28.2E, 23.5E and 19.2E.
The Zero is set to DISEqC A/B/C/D mode with port D set to disabled.
Now when I go into the Satfinder menu the SNR is either always at 0% or sporadically jumping from 0
% to 100%. Moving the dish around and even unplugging the Zero seems to make no difference to this behaviour. If I attempt a manual tune I always get back 0 services found.
This leads me to believe there is a problem with my multi-switch or the configuration of the Zero itself.
Does anybody have any suggestions or can point out where I may have gone wrong?
Thanks.
Thanks.
