VU+ zero WiFi question
Sorry
Could you please some one told me about supported device on vu zero
Is tplink tl-823 supported ?
We need more information about your device:
Image used on your Vuplus Zero:
  • Blackhole 3.0.2I
or
  • OpenBH 06.011
Version model V1 or V2?
Post a photo of your device where it has the Model and version number.
Thanks a lot nunigaia
Here is the information you asked .
If possible please note at least 4 kind of stick so I can find in my country .
Tenda w311u ?
Tplink 722 725 723 821 822
8200nd 751nd 823
Dlink 121 127 125 182 131_e1
Which one should I use .
Confused .
Any suggestions ????????????
:notworthy::notworthy:
I read another topic in French language an using google translate.
They suggested tplink 823n
Is it okay ?
Is it okay ?
Check this one WN725 v2.1, i´ve one ( although i only use lan connection ), i can confirm that both working with:
BlackHole 3.0.2
or
OpenBH 06
Note: Pay attention is a nano usb wireless TP-LINK TL-WN725N v2.1
The chipset is an rt8188eu and about 6€ you can buy this device.
