VU+ Zero
Pedro C
Hi there
I'm installing a brand new Zero for a friend and he will be using a wifi usb dongle at the back. How should I mount it as? Also if I need to add an extra usb or even a third one, will it be OK to use an usb hub for the job and then mount each one of them individually?
Cheers,
Pedro
Hi there
Cheers,
Pedro
The wifi device must be compatible with the drivers and kernel embedded in image. For use more than one usb device for example:
  • Usb Wifi dongle
  • Usb pen drive
  • Usb HDD
You must use a "powered" hub usb 2.0 ( not an usb3.0 retro compatible with 2.0 to avoid problems ).
